> Replacing Rear Sway Bar - Advice to get out? And get bolt unstuck?
post Jun 12, 2012 - 12:40 PM
aspen
Joined Nov 29, '07
From Colorado
I went ahead and picked up some ST Suspensions sway bars. I got the front in OK, but am having a much more difficult time with the rear.
The How-To on here mentions to just drop the gas tank and remove or drop the exhaust (I opted for drop). With just this though, I can't for the life of me get the sway bar out. There isn't enough clearance wheel-side to get it into a position to remove...
So, the how-to included with the 'bar says to remove the large 8-inch stud holding the trailing arms to the wheel hub. I can see where if I do that, I should be able to squeeze the old bar out.
Trouble is, I've been at that stud/bolt for a long time. After a while I got the nut off, but still can't get the bolt itself to budge. I've gone between an impact gun, torch, air hammer, all for several hours to no avail.
Maybe I'm just missing something?
2019 M2, 2005 S2000, 1997 4Runne
post Jun 12, 2012 - 5:56 PM
trdproven
Joined Aug 2, '05
From Guam
not sure if i am on the right mindset here, but in suspension sometimes you have to use a jack to align suspension parts so that they could come out. for example using a jack on the knuckle to remove strut bolts. i might be wrong but thats what i normally come across with, unless you have pics.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 12, 2012 - 7:49 PM
aspen
Joined Nov 29, '07
From Colorado
Bit of an update:
I wound up just cutting the exhaust bolts. I was able to get the old sway bar out.
The new one though, still no luck. I can't get it to quite fit in. Has anyone managed to get the ST sway bar in without removing that trailing arm?
trd, I've tried it through a pretty full range to no avail. I threw some PB Blaster on it to let it sit overnight, then I'll go from there. (Break time for the night).
post Jun 20, 2012 - 9:09 PM
Hirogodsend
Joined Mar 19, '11
From Utah USA
I have been having the same problem. Except the fact that my bolt snapped. The only way I was able to get that sway bar in was after the arm was out of the way.
90' Toyota Celica GT (sold)
99' Toyota Celica GT
post Jun 21, 2012 - 1:27 AM
i did, put in my swaybar. all i can tell you, is it takes time, i partially removed the gas tank.
post Jun 21, 2012 - 2:59 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (njccmd2002 @ Jun 21, 2012 - 2:27 AM) *
lol what a pain haha
エキサイティングカーレーシングチーム!
post Jun 21, 2012 - 6:18 PM
yup, and after 3 hours, i went ahead and played battlefield 3.....
post Jun 22, 2012 - 12:09 PM
aspen
Joined Nov 29, '07
From Colorado
I managed to squeeze it in after dropping the hub from the coilover. What a pain.
On the upshot, the car feels fantastic.
On the downside, I'm going to have to source replacements to all the parts I'll need to cut for when I do my bushings.
Lo-Fi Version Time is now: December 2nd, 2024 - 6:31 PM
