> Start up issues
post Jul 17, 2012 - 12:28 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
I'm having trouble with my celica with start up where its not idling where it should be instead it idles around 200 and would shut off. but this only happens on ocassion. I noticed that 2 of my spark plugs are wet with oil so I cleaned them up and the problem still occurs. I called Toyota and was told to replace the tube seals but this didn't fix the issue. Could it be the valve guide seals at this point? Also my car is not throwing smoke BUT it does smell like burning oil on cold starts till she warms up. Any suggestions would help.
I only want to be faster than the guy next to me.
post Jul 17, 2012 - 5:15 PM
trdproven
Joined Aug 2, '05
From Guam
not sure but valve guide seals usually come with smoke because it leaks down. how is your ignition timing? How did this all start? Try providing a history up to problem.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 18, 2012 - 4:16 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
The timing is good, as far as how this came to be it started happening after I replaced my spark plug wires because all 4 were ripped apart at the point that they connect to the spark plug. A week after I replaced them the problem starting to occur
post Jul 18, 2012 - 5:23 PM
trdproven
Joined Aug 2, '05
From Guam
do you have a leak at your dizzy?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jul 23, 2012 - 1:03 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
QUOTE (trdproven @ Jul 18, 2012 - 5:23 PM) *
sorry but what exactly is a dizzy?
post Jul 23, 2012 - 1:22 PM
rave2n
Joined May 29, '09
From Gainesville, FL
Distributor
post Jul 24, 2012 - 7:11 AM
mi645
Joined May 23, '12
From northridge,CA
My car has the same issue it's a 99 and I replace valve coer and tube deals and it still leaks and occasionally it will idle at cold start so idk what to do anymore but as far as smoke I never seen a sight of it yet
post Jul 24, 2012 - 11:30 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
Also all I do to get rid of the issue is let it warm up a little and give it a quick rev to 5K and it work good as new
post Jul 24, 2012 - 7:03 PM
mi645
Joined May 23, '12
From northridge,CA
I think that might help mine too but I can't rev it up to 5 If its not ready or warmed up cuz eventually it will catch on
post Jul 25, 2012 - 1:48 PM
gotian
Joined Apr 22, '12
From florida
Mine had a similar problem, only difference is it only does it when its really hot outside. In the morning or at night it starts no problem in the middle of the day it seems fuel starved
post Jul 26, 2012 - 11:52 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
So it seems like its not too uncommon, somebody has to have a solution for this annoying issue
post Jul 26, 2012 - 7:32 PM
Zake
Joined Mar 7, '10
From Ft. Lauderdale
mine does that too. (i dont know about the oil part, but the dieing on start-up is my car) only when its really hot outside though, and like a post before, a quick rev and its back to normal. (i dont go to 5k though, just to 2 and then hold it at 1.5 for a few seconds) im taking it to my mechanic on monday and let you know if he fixes it and if so, what it is.
post Jul 27, 2012 - 7:25 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
QUOTE (Zake @ Jul 26, 2012 - 8:32 PM) *
lets hope he atleast gives you an idea of what it may be. its really embarrasing going to school for automotive technology and this problem happens in front of everyone lol.
post Jul 28, 2012 - 10:46 PM
gotian
Joined Apr 22, '12
From florida
i just have to bump this, too many people with the same problems
post Aug 9, 2012 - 9:29 PM
Antz5SFE
Joined Jan 3, '12
try cleaning the throttle body & check air idle control operation.
post Aug 10, 2012 - 7:03 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
yeah, maybe clean out the idle control valve, pull the hose off and see if its sucking much air thru it
Mike W
269awhp / 273ft-lbs
post Aug 13, 2012 - 8:56 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
cleaned out my IACV yesterday and this morning i had trouble starting it. it would turn over and shut off right away. im slowing starting to give up on this.
post Aug 14, 2012 - 9:49 AM
rave2n
Joined May 29, '09
QUOTE (99celiGT @ Aug 13, 2012 - 8:56 AM) *
Another had to do an ECU swap to fix this..have you tried such? Know anyone to swap with?
post Aug 14, 2012 - 2:10 PM
zfjohnson07
Joined Apr 11, '09
ive heard that if your check engine light doesnt illuminate you need a new ecu.
post Aug 15, 2012 - 10:24 AM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
QUOTE (rave2n @ Aug 14, 2012 - 9:49 AM) *
I know nobody else with a ecu I could try. And after cleaning the iacv the problem only got worse cause now it has trouble every morning and it idles rough frown.gif
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: December 11th, 2024 - 12:29 PM
