Enthusiast ![]() ![]() Joined Aug 15, '10 From Nevis, West Indies Currently Offline Reputation: 0 (0%) ![]() |
wastegate actuator is acting up and sticking open randomly from i time to time, any suggestions? other than garrett turbo with external wastegate
![]() -------------------- 1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies |
anyone?
well, either you take the downpipe off and see if the flapper is hanging on the downpipe flange, and grind the flange to create more clearance, or the actuator itself could be bad, which you can test by putting 7-12psi to the actuator using compressed air or a bike tire pump, and watch the arm movement.
pretty straight forward stuff. -------------------- Former Team 5SFTE pro member ;)
well, either you take the downpipe off and see if the flapper is hanging on the downpipe flange, and grind the flange to create more clearance, or the actuator itself could be bad, which you can test by putting 7-12psi to the actuator using compressed air or a bike tire pump, and watch the arm movement. pretty straight forward stuff. ok buddy, I'm pretty certain my actuator is bad, should I try and get a universal one off ebay? -------------------- 1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
not if you have a stock turbo.
you can find actuators here, alltrac.net or mr2oc...just poke around some. if its a 20b, i would PM gottagoturbo, he is always parting out gt-4's. -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 20th, 2025 - 9:51 PM |
