> car wont turn all the way off, engine stops but some electrical stays on need help!
post Sep 15, 2012 - 7:01 AM
mgnt232
Joined Mar 16, '09
ok so walk out this morning an my lights were on. but i got home like midnight so i know i didnt leave them on, and i opened the door turned them off, they turned off thought it was a little odd
got to my friends this morning and he goes hey did u leave ur lights on? (i never leave them on)
walked out and lights are.like flicking on and off, beeping like the door.is open (keys in my pocket) so i turn it on everything stops. turn.it off and the lights come.on kinda dim ( brake/oil ect) but i have no damn keys in.
then the radiator fan and the ac starts like the car is on
if anyone.has annny ideas let me know please! so far nothing has happened o far while im driving only when the.car is off but i have a 3+ hout drive back to.base.Sunday
let me know.asap ill be.checking this all day and updating if i find anything more
oh all the fuses underthe dash seems to be good i
will.check.them all later
thank you
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Sep 15, 2012 - 10:16 AM
richee3
Joined Jun 29, '08
From Denver
That sounds like a ground issue. Weird things happen when grounds go bad. One of my Celicas said I was going 30 mph when I turned my parking lights on and it went up to 50 with the headlights on, along with other weird issues. I had pulled the motor out and did a few small things here and there and disconnected a ground wire in the process. Problem solved.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 15, 2012 - 12:01 PM
mgnt232
Joined Mar 16, '09
yeah ill replace the battery and chassis ground, but i havent touched ne thing wiring wise at all in this car.
im just shooying.in the dark is there amyway its like an ignition switch or something, it only does the normal things as if my car was on,, but when ita actually on everything is fine
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Sep 15, 2012 - 12:27 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
QUOTE (mgnt232 @ Sep 15, 2012 - 8:01 AM) *
thank you
The only explanation I can come up with would be that a relay is malfunctioning.
All the relays in your car have constant power from the battery(terminal 30 in the picture), and they are also connected to the ingition/fusebox via terminal 86 or 85. If there was an internal short circuit inside the relay it could potentially send current back into the ignition switch or fusebox and turn on either an individual circuit or possibly the entire car depending on the circuit path.
Try pulling one fuse at a time until you find the circuit that is powering on your car. Obviously any device that is on will shut off when you pull the fuse in its circuit, so you are looking for the fuse that will kill ALL the incorrect power when pulled not just its individual circuit. Alternatively, you could pull relays instead of fuses to find the problem, but these are more difficult to remove.
This post has been edited by Special_Edy: Sep 15, 2012 - 12:28 PM
post Sep 15, 2012 - 1:05 PM
zfjohnson07
Joined Apr 11, '09
Sounds like an alarm car alarm . Mine does that makes a clicking noise like the yield lights are on and lights flicker
post Sep 15, 2012 - 6:44 PM
mgnt232
Joined Mar 16, '09
ok had finally got a minute to look at it and figure it out and reconnected my negative battery cable and my alarm went off. And it wouldnt start now. But i could hear a relay under the dash. Tore it apart and found where they like hid the alarm system and i assume the relay in it is broken cause anytime i tried anything it clicked.
Anyway unhooked all the wired and the car starts fine and no more problems, thanks guys.
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
Lo-Fi Version Time is now: January 10th, 2025 - 5:08 PM
