7 Step LED Gauge Conversion, 7 Steps in order to change your 6th Gen Celica Gauge ligting to LED |
Sep 27, 2012 - 11:32 PM |
Enthusiast Joined Sep 23, '12 From Australia Currently Offline Reputation: 4 (100%) |
Okay, This is my first post , and I am not sure whether this has been done or not , but I have searched for a while for a walkthrough on this to no real luck . Anyway, I have made a step-by-step walkthrough for removing the instrument cluster and replacing the internal bulbs with LED's . I got my LEDs off eBay with a search of '1994 Celica Dashboard' and so on...
This is for changing a 1994/5 (ST204) Celica gauge light, but I am pretty sure the 1995-1999 also uses the same method... What you'll need: - 2 Screwdrivers (one mini, but both same head size), - 3 LED which fit the OEM socket (eBay is your friend), Optionally: - a fourth smaller bulb, (usually included with the LED kit) Let's take a look at the before shot: A repulsive green/yellow colour... Time to change that. Step 1: Remove ignition trim Easier done than said (No really, it just pops out), there are two 'grips' these will make it so much easier. Once the trim is removed, just place it hanging over the other side of the dash, we don't need it out. (Note: the black screw next to the ignition.) Step 2: Further trim removal: Locate the black screw on the other side of the instrument cluster (Note the screw in the background): Back over to the ignition, remember that screw I told you to note? take it out. Step 3: Hidden Screws: Before you go ripping out your trim, there are two 'hidden' screws. well actually, they aren't hidden at all. There general location (You'll need a small screwdriver with the same head size here): Step 4: Removing the gauge cluster: Probably the second most daunting part of this task, but remember that screw in the background? all you have to do is remove it and 3 others. Locate these under and above the cluster: Note: Do NOT forget the two circled screws above the cluster or you'll have a bad time. Step 5: Remove the cluster: Now that the screws are removed, the cluster slides out. This can be challenging first attempt with the steering wheel. But, it is possible. Once removed, disconnect all the wire harnesses. The gauge cluster: Reverse: Step 6: Changing bulbs: Now, this seems like the most daunting task, but really it isn't... If you have consulted your Owner's Manual or the Workshop Manual, all you have to do is change the light with an LED of that socket type... Now, those circled in red are to be replace, the one circled in yellow is optional. The yellow one is a different bulb type to the red but, the kits off eBay include both... It is up to you, I found that the yellow illuminated my low fuel light and so decided not to put it in... The actual removal of the bulbs is easy, twist by the green holder, pull the wedge base bulb (with green condom) out, and push LED in... VERY IMPORTANT: with LED bulbs, polarity matters. This is where testing comes into play, place the LED bulb in the holder, it doesn't matter what way as you can screw the lights in both ways. Screw the LED into the cluster and TEST IT. take it to the car, plug in the harnesses and turn the lights on, if the gauge doesn't light up, remove and turn the green plug around. It should now work. Step 7: Putting it back in: Now really, you don't need a guide for this because it is so simple, but anyway... Follow from step 5 in reverse. CONGRATULATIONS! Mission Accomplished. Enjoy! -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Sep 28, 2012 - 12:37 AM |
Very good! Thanks and welcome!
Sep 28, 2012 - 1:57 AM |
Sep 28, 2012 - 5:45 AM |
We actually do have this covered in a couple of places (a link in the stickies and a how-to on the main page) but this is the first how-to in our forums. Good first post.
Sep 28, 2012 - 6:22 AM |
We actually do have this covered in a couple of places (a link in the stickies and a how-to on the main page) but this is the first how-to in our forums. Good first post. Thanks I couldn't find one that was for my particular model, the 1994/5 Pre facelift... There are a few small changes in parts between it and the 1996-1999 models haha -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Sep 30, 2012 - 11:29 PM |
Enthusiast Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Very cool, but one question; can the LEDs you're using sustain the dimming function, or are they only operating at certain brightness?
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Oct 1, 2012 - 3:09 AM |
Enthusiast Joined Jul 17, '12 From Slovenia Currently Offline Reputation: 0 (0%) |
I also replaced the T5 light bulbs with LEDs, but had problem with some:
- Airbag light was always partially on, when turning the key to ON, it turned on normally, but then just dimmed after 6 seconds and stayed that way - Blue LED for high beams indicator blinded me at night - I skipped battery and warning LEDs, as suggested in tutorial on Celica-Club Replaced turn signals with green LEDs, red indicators wit red LEDs and the rest (mostly yellow/orange) with white leds. Just a little heads-up if somebody decides to do the same, as here is just one T5 instructed to be replaced -------------------- |
Oct 1, 2012 - 5:33 PM |
Very cool, but one question; can the LEDs you're using sustain the dimming function, or are they only operating at certain brightness? Yes, the dimming function works fine. Also socket types behind the cluster are: 3 Wedge Base T10 Bulbs and the optional bulb is a Wedge Base T5 I also replaced the T5 light bulbs with LEDs, but had problem with some: - Airbag light was always partially on, when turning the key to ON, it turned on normally, but then just dimmed after 6 seconds and stayed that way - Blue LED for high beams indicator blinded me at night - I skipped battery and warning LEDs, as suggested in tutorial on Celica-Club Replaced turn signals with green LEDs, red indicators wit red LEDs and the rest (mostly yellow/orange) with white leds. Just a little heads-up if somebody decides to do the same, as here is just one T5 instructed to be replaced Yes this too is also true, The LED's are ALOT brighter than the Incandesent bulbs.... Even after taking the optional T5 bulb out, I find that at night my fuel light still glows... I've left all the T5s alone at the moment -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Oct 12, 2012 - 6:42 PM |
I dont ever remember seeing a T5 backlight on a manual cluster, must be an aussie thing.
-------------------- Mike W
Oct 13, 2012 - 5:50 PM |
I dont ever remember seeing a T5 backlight on a manual cluster, must be an aussie thing. Maybe, Mine has 3 T10 which are the complete 'backlight' and then 15 T5's which are all the warning lights and indicators... -------------------- ------------------------------| White '94 Celica | Bought 11/05/12 | Sold 12/05/15 |------------------------------ |
Lo-Fi Version | Time is now: December 4th, 2024 - 5:00 PM |
