![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
Date: Monday, November 19 2012 02:10 PM Subject: RE: BIG order... UPDATE: 1) The contents of an engine overhaul gasket set vary from one engine to another. Basically, 04111-74512 does include these parts: Head gasket Valve cover gasket Valve cover grommets Timing cover gasket Valve stem seals Camshaft seal Intake manifold gasket Exhaust manifold gasket Throttle body gasket Oil cooler o-rings Front crankshaft seal Oil pump gasket Rear crankshaft seal Rear main seal retainer gasket Water outlet gasket Water bypass pipe gaskets and o-rings Fuel injector o-rings and insulators Thermostat gasket (also supplied with water pump) It does not include these parts: 1. Oil pan gasket (use FIPG oil sealant 00295-00103; there is no oil pan gasket) 2. Oil pump shaft seal 15165-88382 (the oil pump is sold as an assembled unit w/ seal installed) 3. Oil pump o-ring 15188-03011 (the oil pump is sold as an assembled unit w/ o-ring installed) 4. Water pump gasket (the water pump is sold as an assembled unit w/ gasket installed) 2) I do not know if this was a question or not. Water pump is 16100-79185-83. Your VIN calls for oil pump 15100-74060. The most recent Camry 5S-FE oil pump is 15100-74030. Toyota does not give us engineering data or flow rates, so if you want to deviate from stock, you will need to do your own research on the forums to determine which parts to use. 3) The gasket set most likely includes the same type of head gasket the car came with. We cannot make substitutions. If you want a different one you will need to order it separately. The part number for a later model head gasket is 11115–74120. 4) I do not know if this was a question or not. Idler no.1 is 13505-74011; tension spring is 90507-17003; idler no.2 is 13503-63011. --------------- Does anybody know what the so called "Engine Overhaul Gasket Kit" from Toyota include? I contacted a parts reseller that only sells OE toyota stuff and he simply sent me a diagram which looks like playdoh figures with some lines and stuff. I asked if he had a list of the parts that it included and he said "no, sorry, this is all I have''... This post has been edited by Syaoran: Nov 20, 2012 - 6:40 PM -------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
it comes with everything. period. including head gasket, and yes its factory 3 layer steel
anything missing from it will come with other parts. example, if you buy the 2 piece water pump (pump and housing) it will come with new orings n **** -------------------- Mike W
it comes with everything. period. including head gasket, and yes its factory 3 layer steel anything missing from it will come with other parts. example, if you buy the 2 piece water pump (pump and housing) it will come with new orings n **** Even for MY94 Celicas? At least for the MR2 guys, their 3SGTE kit for 92 3SGTE comes with a graphite gasket from the factory, because that year came with graphite headgasket. I contacted Lithia Toyota to see what they tell me. -------------------- 1993 Celica GT Coupe - sold
well, if you're talking about an st205 gasket kit then yeah, assuming thats what you're going to order
sorry, are you meaning st204 gasket kit? i got no idea on their head gasket sorry, but likewise on it including everything
sorry, are you meaning st204 gasket kit? i got no idea on their head gasket sorry, but likewise on it including everything Yes it's for a 5S-FE. -------------------- 1993 Celica GT Coupe - sold
it will come with the metal head gasket, all the gasket kits come with metal gaskets now. the 7A originally came with a graphite gasket, now they come with a metal gasket. if you feel better, get one thats for a 99 celica. it will have everything. all the valve seals, cam seals, front and rear mains. the only gaskets it doe snot come with are the oil pump gaskets for on the pump. the one under the pulley and the wing shape inside the pump
it will come with the metal head gasket, all the gasket kits come with metal gaskets now. the 7A originally came with a graphite gasket, now they come with a metal gasket. if you feel better, get one thats for a 99 celica. it will have everything. all the valve seals, cam seals, front and rear mains. the only gaskets it doe snot come with are the oil pump gaskets for on the pump. the one under the pulley and the wing shape inside the pump Thanks, I'm guessing the oil pump assembly should bring everything but the cork/rubber gasket for the pump right? I have a couple of questions regarding the 98+ oil pump but I'll search for those first. -------------------- 1993 Celica GT Coupe - sold
the oil pump gasket will be metal. if you get a new pump, it will have the new seals in it already.
Updated the first post. Got a reply from Lithia Toyota of Springfield with some part numbers as well. For those whom this may be of benefit, glad I could help.
Lo-Fi Version | Time is now: February 22nd, 2025 - 5:03 AM |
