> Could someone identify this?
post Dec 14, 2012 - 4:50 AM
1994whitecelicag...
Joined Nov 13, '12
From Sacramento
Hi 6GC owners!
So I've been working on changing the clutch on my celica but I ran into a problem. Could someone help me identify the name of this part (this is on the transmission, towards the back)? But more importantly, how do I take it off? There doesn't feel like a release button where I can just pull it off.. There is also 3 screws and a small bolt holding it, but I'm very hesitant to take those off. Should I take those screws off? How would I go about unplugging this part?
This post has been edited by 1994whitecelicagt: Dec 14, 2012 - 4:53 AM
post Dec 14, 2012 - 6:31 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Looks like the speedsensor to me. Never took it off though
JDM ST205
post Dec 14, 2012 - 6:49 AM
i see some screws there, but it should come out as any other plug? if not the sensor for speed, is the reverse sensor,
post Dec 14, 2012 - 6:52 AM
richee3
Joined Jun 29, '08
From Denver
Speed sensor. It takes some effort but it will unplug.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Dec 14, 2012 - 8:23 AM
rave2n
Joined May 29, '09
From Gainesville, FL
SQEEEEEEEZZZZZZEEEE
post Dec 14, 2012 - 8:35 AM
Clean it down with brake cleaner so you can get a grab on it.
post Dec 14, 2012 - 9:31 AM
mkernz22
Joined May 10, '10
From MA
I remeber taking that plug off lol boy was it fun
post Dec 14, 2012 - 9:33 AM
Ted95
Joined Mar 8, '09
From Westport, MA
just take a flat head screw driver, theres a tab on the back side of the plug (to the left in the pic behind the wires) just push the flat head against it and pull at the same time.. like richee said it will take little effort but it will come out.
st205 powered ss3 coupe
post Dec 14, 2012 - 12:16 PM
1994whitecelicag...
Joined Nov 13, '12
From Sacramento
Thanks everybody! I started taking one of the little screws off last night. But then when I really thought about it, there's no way that they would design it like that.... So I'll try cleaning it off with the brake cleaner, and pushing in a flathead screwdriver. I guess it's not going to be fun to take off....
post Dec 14, 2012 - 10:06 PM
no no no, do not use a screwdriver. just pinch it at the wires and pull up. look at the TPS sensor, its the same style plug.
post Dec 15, 2012 - 11:59 AM
czwalga
Joined Sep 27, '10
From pittsburgh
QUOTE (Smaay @ Dec 14, 2012 - 10:06 PM) *
Not sure if you ever have to deal with them in so cal... but the weather ruins those connectors over 10+ years in the north. A lot of times you can push it down the entire way and the locking mechanism wont even budge.
A lot of other times the tab just snaps right off because they are so brittle. Just pushing and pulling doesn't always work.
This post has been edited by czwalga: Dec 15, 2012 - 12:02 PM
-10 F150
post Dec 15, 2012 - 1:19 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Here in North Texas they are brittle as hell. I always push down the tab with a screwdriver and then I start wiggling the plug back and forth while pulling it with my other hand.
There is definately an art to removing the plugs without breaking anything but you will get it
post Dec 15, 2012 - 1:41 PM
oh they get plenty brittle here too, but using s screwdriver is just looking for trouble.
post Dec 15, 2012 - 1:58 PM
Squeeze tab with pliers, use screw driver between sensor and connector to start moving off, then once its cleared the lock tab it should wiggle off. Sometimes I need use to use a pick to lift the clip off the tab then use the screw driver for leverage. I find that dousing the connection in silicone spray lube after cleaning it with brake cleaner usually helps. I've even had to go so far as to gently heat some with a heat gun to un seize them! Luckily never on a Toyota, just an old Ford from the 80's. The plastic halves had melted together from heat and I had to un-melt them a little.
post Dec 16, 2012 - 1:40 PM
1994whitecelicag...
Joined Nov 13, '12
From Sacramento
I finally got it off after dosing it with some brake cleaner and WD-40. The WD-40 worked like a charm and it came right off after that. The screw driver method didn't work out very well, all it really needed was alot of cleaning and lube.
post Dec 17, 2012 - 7:26 AM
Ted95
Joined Mar 8, '09
From Westport, MA
never had an issue here with the method, but glad to hear you were successful one way or another.
Lo-Fi Version Time is now: December 10th, 2024 - 11:44 AM
