> Brakes acting funny
post Dec 22, 2012 - 2:27 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
You know when u replace pads and u press the brakes to bring back the pressure in the brakes.
Like the first Time the pedal depresses wayy to much and the next time it's better
Well I noticed my car did that yest. For the first time (I didn't replace pads just did it randomly while driving)
It's doing it after every other stop. Example:
I get out of my house driveway, i press the brake at the stop sign, it depresses too much, I let go and pump it again its normal. Does it again when in getting out of the neighborhood.
Does NOT do it at the light, but at the next light after that. And it continues this way
Also noticed in an empty lot, when the pedal is depressed too much, and I kept pushing it, it locked only driver side
I have drums in the back and calipers in the front
Could It be bad fluid or does it sound like the caliper itself? The fluids not low it's b/w min and max
But does look kinda dark, but I've seen worse
post Dec 24, 2012 - 2:42 PM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
Did you bleed your brakes after changing them? Sounds like you may have some air pockets in your brake lines. You should never have to change your brake fluid unless it get contaminated, its only there to create pressure to close the calipers.
post Dec 24, 2012 - 9:48 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (cyberblader1130 @ Dec 24, 2012 - 3:42 PM) *
I DID NOT change my brakes, it just randomly happened...the shop said my master cylinder is out, estimated 600,
I bleeded all 4 brakes but still not better.
Hopping to get a new cylinder by wed and replace it myself.
post Dec 24, 2012 - 11:27 PM
cheela
Joined Feb 2, '07
From Berlin, WI
my sister's bf's civic did that for a while and it did turn out to be the master cylinder.
happened on and off randomly.
post Dec 25, 2012 - 1:17 AM
Sure sounds like a bad master, but pop off the rear drums and make sure the wheel cylinders are not leaking.
post Dec 25, 2012 - 8:13 PM
Syaoran
Joined Jan 4, '12
From US
Sounds like a bad master cyl. Mine did that a long time ago. Make sure that you prime it if you decide to replace it yourself. I didn't and ended up damaging the internal seals of the new one.
Priming = filling reservoir partially before installing and pushing the piston with a blunt object to fill the brake master with brake fluid.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
Lo-Fi Version Time is now: December 3rd, 2024 - 5:43 AM
