> Rims, Tires and possible issue
post Dec 24, 2012 - 12:58 AM
cyberblader1130
Joined Oct 24, '09
From Appleton, Wisconsin 54915
I really hope this is in the right spot, if not please move it. I've never gotten rims before but i want to upgrade from my OEM Alloys to 18s. I've picked the exact tire size i want but im not sure what rims to get.
The Tire size i want is 235, 35, R18. I already have 25 mm spacers to use as well if need be. I am also sitting on KYB Mounts, GR2 Struts, Tein S Techs,(drop is estimated at 35 mm in the front and 23 mm in the back.)
I have some questions for the more experienced members.....
Will i have issues with my fenders rubbing on my tires when i hit bumps? Will the width of the tire be an issue when turning? What brands of rims and tires are good to look for? How do you change your speedo to the correct speed when changing tire/rim size?
Any other advice would be nice regardless but i want to keep that tire size unless it won't work...
Like i said i don't know much about rims but i would like to get a set for the summer.
post Dec 24, 2012 - 3:48 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
the overall diameter is 24.5 just like my current 16 inch tires. If you were to buy a tire that has a 25.2 inch diameter then it will rub on the inside part of the front wheel well. but you wont have that problem
there isn't a way to correct the speedo, but I could be wrong. google is your friend there... 17 inch is best in performance/looks. 35 sidewall is very thin and you'll feel the road too much....
post Dec 24, 2012 - 3:12 PM
cyberblader1130
Joined Oct 24, '09
How would the tire size 215 40 R17 work out? If i am correct that would mean i need a rim size of 17" x 8.5" right? Gunmetal sounds like a good pick for color but what kind? I dont know anything about rims or where to buy them so if anyone knows a good place local or online it would be much appreciated. Also suggestions on what brand and if i should go with an offset to avoid using spacers?
post Dec 24, 2012 - 8:24 PM
dangqiwu
Joined Sep 9, '12
QUOTE (cyberblader1130 @ Dec 24, 2012 - 3:12 PM) *
I bought one wheel rim at partsgeek.com
post Dec 25, 2012 - 3:32 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (cyberblader1130 @ Dec 24, 2012 - 4:12 PM) *
a 215/45R17 is a great size and will fit. You can fit a 7-8 inch wide rim on that tire...
post Dec 25, 2012 - 8:10 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
i had 225/40R18 on my car at one point, didnt like em at all, looked great but way too heavy, feels like towing a house when your off-boost
Mike W
269awhp / 273ft-lbs
post Dec 25, 2012 - 9:07 PM
cyberblader1130
Joined Oct 24, '09
Sounds good to me. Thank you all kindly. Now i just need to find a Rim style i like. Any suggestions would be greatly appreciated, maybe some photos or point me in the right direction?
Lo-Fi Version Time is now: December 2nd, 2024 - 7:50 AM
