94-95 JDM headlight question~relay or not? |
Dec 28, 2012 - 12:50 PM |
Enthusiast Joined Nov 30, '12 From Ohio Currently Offline Reputation: 0 (0%) |
Do the 94-95 JDM headlight "parking lights" have thier own relay to turn them on when the marker lights are turned on or are they simply tied into the marker light circuit and run off the same fuse as the marker lights?
If someone with this OEM setup (or who knows) please let me know as I am needing to wire in my cars lights, but dont want to go to the trouble of adding another relay and wires if all I have to do is tap into the side marker 12V power. Also, if its all on the same circuit, what circuit is it in? and what size fuse is used. Thank you very much. |
Dec 28, 2012 - 6:54 PM |
you dont need any relays. if you want them to come on with the driving lights, then just tap into the side marker wiring on the fenders!
May 28, 2014 - 6:57 PM |
Enthusiast Joined Dec 17, '13 From Las Vegas Currently Offline Reputation: 0 (0%) |
Lo-Fi Version | Time is now: January 10th, 2025 - 1:44 AM |
