> Crank Help
post Jan 1, 2013 - 4:19 PM
shai
Joined Aug 19, '09
From westminster
My Car Just Stop Starting Yesterday When I Was Driving. I've Check The Timing Belt First And It Was Good, I've Check The Spark Plugs And Wires And Its Good, Then I Checked For Spark To See If It's The Ignition Coil And Distributor And It's Not, Checked The Crank Sensor And It's Good, Put Some Starting Fluid In To See If It's The Fuel But It's Not... Gonna Get The Ignition Coil Check At Advance Auto Now ... And Oh And I Just Bought An New Battery For The Car. I Have An 95 Celica GT With An ST185 Swap I Really Dont Know What Is The Problem Anymore Please Help.....
post Jan 1, 2013 - 7:26 PM
does it turn over and just not run, or when you turn the key nothing happens?
post Jan 1, 2013 - 9:19 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
Fuel press?
post Jan 1, 2013 - 9:36 PM
shai
Joined Aug 19, '09
From westminster
QUOTE (Smaay @ Jan 1, 2013 - 7:26 PM) *
it turns over but just wont start......
and no fuel pressure is right on mark.....beside if it was the fuel then the starting fluid spray would of work..... right???? i am completely out of ideas....... and Ignition Coil came back perfect what to do....
This post has been edited by shai: Jan 1, 2013 - 9:40 PM
post Jan 1, 2013 - 10:20 PM
enderswift
Joined Jul 12, '08
when you say you checked the plugs, did you take one out and crank the motor to see if it was generating an arc?
post Jan 1, 2013 - 10:45 PM
Neon90424
Joined Jan 19, '11
i would put the blame on spark if you have fuel...
maybe a fuse
post Jan 2, 2013 - 11:51 AM
shai
Joined Aug 19, '09
From westminster
QUOTE (enderswift @ Jan 1, 2013 - 11:20 PM) *
yup took each one out one by one to check spark using jumper cables all have spark...i just dont know anymore.......
and all my fuses are just fine.....i've replaced all of my main fuses and still nothing....
This post has been edited by shai: Jan 2, 2013 - 11:52 AM
post Jan 2, 2013 - 11:54 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
timing could be off to the point where it wont start
エキサイティングカーレーシングチーム!
post Jan 2, 2013 - 12:23 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Compression, fuel and spark.
Spray starting fluid(ether) into the intake or pour an ounce of gas inside it so that it can get the the cylinders. Now try to start the car. If it tries to sputter to life you have a fuel related issue, if it still wont start you have an ignition related issue.
post Jan 2, 2013 - 2:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
Check your grounds, poor grounds can keep a car from starting.
2001 Miata LS 5-speed
post Jan 2, 2013 - 4:58 PM
Neon90424
Joined Jan 19, '11
bad ground actually caused my car not to crank...but started by pushing it...
post Jan 2, 2013 - 6:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hey that's an idea, try to push start it.
post Jan 2, 2013 - 7:07 PM
shai
Joined Aug 19, '09
From westminster
took it apart and checked the time it's all correct , tried push start won't start, i did say that i've used starting fluid already so thats out of the question.....all of my ground wires are correct and should be fine.....(SO STRESSFUL) confused.gif kindasad.gif
post Jan 2, 2013 - 7:58 PM
enderswift
Joined Jul 12, '08
If you have spark, fuel, and correct timing, then the only thing I can think of is that your iac is stuck closed. So while you crank the engine cant draw any air. Try cranking while lightly pressing on the gas to crack the throttle.
I only bring this up because I once saw someone pull a vacuum while compression testing lol. Turned out their iac was messed up
post Jan 2, 2013 - 8:23 PM
shai
Joined Aug 19, '09
From westminster
QUOTE (enderswift @ Jan 2, 2013 - 7:58 PM) *
it's getting plenty of air and the throttle opens perfectly.
post Jan 2, 2013 - 9:16 PM
Neon90424
Joined Jan 19, '11
so its not fuses, not spark, not fuel pressure... wont start by pushing has vacuum grounding is ok bat is ok cables are ok and arking...
if you remove the spark plugs and cranking the engine does fuel spurt out of the holes? thats how I check that its getting fuel...cuz Im running out of ideas...
you could go war of the worlds on it and CHANge duh solenoid
post Jan 2, 2013 - 10:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
Perhaps it's the ECU. About the only other thing I can think of.
post Jan 2, 2013 - 11:58 PM
enderswift
Joined Jul 12, '08
Did you check your ignition timing? Spark could be firing at the wrong time
post Jan 3, 2013 - 12:30 AM
trdproven
Joined Aug 2, '05
From Guam
some timing issue or ECU is left or a electrical problem.
dumb question but is there still a timing belt on there.
This post has been edited by trdproven: Jan 3, 2013 - 12:31 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 3, 2013 - 12:33 AM
shai
Joined Aug 19, '09
From westminster
I'm 100% sure it's not the ECU... All Wires Is Fine...And Yes Timing Belt is still on
ignition timing is fine
This post has been edited by shai: Jan 3, 2013 - 12:34 AM
Lo-Fi Version Time is now: December 1st, 2024 - 11:04 PM
