4age 20v clutch/flywheel, searched and found a little info. need more |
Jan 4, 2013 - 3:01 PM |
Enthusiast Joined Nov 25, '08 From dillsburg pennsylvania united states Currently Offline Reputation: 12 (100%) |
i bought a 4age 20v and im having a hell of a time finding freaking parts haha. maybe due to the japan only engine. any way, ive seen that the 7a flutch would work? is this true. and as far as flywheel options. how many bolts do the crank have for the 4age? i got timing belt, pully, water pump, and getting a .8mm head gasket from trd. but i want to put a new flywheel and clutch in before the installing proceeds. any help is sweet and greatly appreciaclub4ag isnt working at the moment or id look there too
This post has been edited by TerBeau: Jan 4, 2013 - 3:04 PM -------------------- those with golf balls golf those with real balls race |
Jan 4, 2013 - 3:15 PM |
why why why?
Jan 4, 2013 - 3:34 PM |
cuz cuz cuz... motor.. trans.. ecu. harness already switched to work on the celica.. ignitor, afm, external coil. and longer throttle cable for 500 bucks. an idiot would pass this up!
Jan 4, 2013 - 3:38 PM |
and its different. has potential for hp and can keep it a dd in the summer time! im not going bawlz on gains and ****. i want a bit more powa and keep it simple
Jan 5, 2013 - 1:44 AM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
If you buy a lightweight flywheel off ebay any of the 4age 16V flywheels will work, but usually the seller will send you something that only the clutch on a 4AFE will fit on. If you get a light flywheel and clutch combo then usually you don't have to stress over the details. (The 4AFE clutch is a little smaller in diameter than the 4age 16V)
PM me if you are interested, I have a brand new lightweight flywheel with a 4AFE clutch kit that is mated on to my ST engine and transmission but has 0 Miles, since I have long abandoned the project. |
Jan 5, 2013 - 2:02 AM |
If you buy a lightweight flywheel off ebay any of the 4age 16V flywheels will work, but usually the seller will send you something that only the clutch on a 4AFE will fit on. If you get a light flywheel and clutch combo then usually you don't have to stress over the details. (The 4AFE clutch is a little smaller in diameter than the 4age 16V) PM me if you are interested, I have a brand new lightweight flywheel with a 4AFE clutch kit that is mated on to my ST engine and transmission but has 0 Miles, since I have long abandoned the project. pmed thANKS -------------------- those with golf balls golf those with real balls race |
Lo-Fi Version | Time is now: January 10th, 2025 - 7:44 PM |
