![]() Enthusiast ![]() Joined Nov 7, '12 From Puerto Rico Currently Offline Reputation: 0 (0%) ![]() |
Im pretty sure this topic has been discussed hundreds of times already but lets see if someone can enlighten me, im pretty sure the 2nd gen 3sgte can be swapped into our celicas but from what i read, people encounter a problem with the shifter cables or something like that based off becuase of the way the transmission is positioned on the mr2. Can the GT transmission be mated with the 2nd gen mr2? If so, what shifter cables should be used?
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '08 From Denver Currently Online Reputation: 59 (100%) ![]() |
The GT trans can be used, so that isn't an issue. However, coolant outlets are different and there are other differences as well. All minor, but they can be a headache.
This post has been edited by richee3: Jan 11, 2013 - 11:36 AM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
I say go straight to the 3rd gen. It's about as plug an play as it gets.
because the 2nd gen is older electronics it more of a wiring issue. the 3rd gen was factory in the 6th gen celica so the wiring is very minimal.
Lo-Fi Version | Time is now: February 19th, 2025 - 10:31 PM |
