> electrical short?
post Jan 29, 2013 - 1:45 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
heyy guys, i drive a 95 ST that has a new battery and alternator, new grounds as well as new ends on the battery cables. for some odd reason the battery died this morning (hasnt been driven in maybe a week). lights arent on or anything. what could be the cause??????
post Jan 29, 2013 - 1:56 PM
tto010
Joined Jul 6, '12
From NORWAY
If it sparks when the battery is charged and you put the + pole on, something is leeching from the battery (when ignition is off ofc...).
post Jan 29, 2013 - 2:01 PM
rave2n
Joined May 29, '09
From Gainesville, FL
QUOTE (tto010 @ Jan 29, 2013 - 2:56 PM) *
Every car I've had sparks when you finish the circuit that is attaching the battery.
Never had a dead battery because of such.
But, something is leeching your battery. Those new grounds you have I would look into first.
Also use a multimeter to test your battery.
post Jan 29, 2013 - 2:06 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
ill check the grounds the ones i replaced were the one from trans to core support and one from the head to near the passenger strut....
QUOTE (rave2n @ Jan 29, 2013 - 2:01 PM) *
post Jan 29, 2013 - 2:20 PM
tto010
Joined Jul 6, '12
From NORWAY
QUOTE (rave2n @ Jan 29, 2013 - 3:01 PM) *
Mine doesnt spark...
Edit: And i ment like a big spark.... Not a small bzzdt when you put it on, but something a bit bigger then that...
This post has been edited by tto010: Jan 29, 2013 - 2:27 PM
post Jan 29, 2013 - 4:37 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
why would the battery spark though, if its new (from october)
post Jan 31, 2013 - 3:51 PM
tto010
Joined Jul 6, '12
From NORWAY
QUOTE (CAcelica29 @ Jan 29, 2013 - 5:37 PM) *
It is when you connect the pole to the battery... It will spark because you will have a "bad connection" Momentarialy and it will make a spark if its drawing any current.
You can hear the sparking if you balance a lightswitch between on and off. Because there isnt enough contact between the two sides of the switch, it will come a spark....
post Jan 31, 2013 - 4:55 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
QUOTE (tto010 @ Jan 31, 2013 - 3:51 PM) *
so if something is drawing off the battery it will spark momentarily?
post Feb 1, 2013 - 12:10 PM
tto010
Joined Jul 6, '12
From NORWAY
QUOTE (CAcelica29 @ Jan 31, 2013 - 5:55 PM) *
when you connect it to the circular clamp thing.
post Feb 1, 2013 - 2:26 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Lol its called parasitic battery drain.
To test for it-
Remove the negative battery cable from the battery
make sure everything is turned off and the doors are shut. You do not want to open the doors or turn the ignition on during this test, the fuse in your multimeter will only handle 3-10amps of current.
Use a hose clamp, tape or your spare hand to secure the negetive probe of your multimeter to the negative terminal of the battery.
Set your multimeter to measure milliamps in DC(the dotted line not the wavy one).
Connect the positive probe of the multimeter to the negative battery cable/clamp to complete the car's circuit. You can usually wedge it into a crevice on the clamp.
The normal reading shouldn't be much more than 10milliamps, .01 amps.
You can remove the fuses 1 at a time until you find the one that is pulling the majority of the amperage. This is your problem circuit, its normal for the ECU, clock, stereo and amplifyers to draw a slight amount when powered down.
Be wary of opening the doors to check the interior fusebox, you don't want to exceed the fuse rating on the multimeter.
Good luck and be sure to post your results or any questions.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 9th, 2025 - 12:53 PM
