> Ill effects of wheel size?, need some help
post Feb 2, 2013 - 4:39 AM
NOVAKx17
Joined Oct 7, '09
hey everyone, quick question
will it effect my ride at all if i have 2 different size tires on my rims?
i have 2 - 215/35/18s
and 2 - 225/40/18s
i was planning on running the 225/ 40s in the front
and the 215/35s in the rear...
can anyone think of anything that would go wrong from this as long as i keep the pairs matching like 2 in the front and
2 in the rear? thanks guys
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Feb 2, 2013 - 11:07 AM
Syaoran
Joined Jan 4, '12
From US
Right now they're not of the same diameter.
if you're doing 215/35, then you need to either get 215/35, or 195/40, or 235/30.
if you're doing 225/40, you need either 225/40, 205/45 or 245/35.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Feb 2, 2013 - 6:30 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
If you don't have AWD, having different tire sizes between front and back shouldn't affect you as long as you're going in a straight line. One axle simply has to spin faster than the other to make up the difference in distance covered per rotation.
However, you'll notice it in the handling.
The 215/35 are 23.92 inches in diametre, close enough to stock to work. A 225/40 is 25.08 inches in diametre, well outside of what should be used to maintain speedometre accuracy and handling characteristics as designed.
post Feb 3, 2013 - 8:02 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
if what your aiming for is oversteer, i'd stick to the same size all round, buy 2 sports compound tyres for the front and 2 plastic tyres for the rear
Mike W
269awhp / 273ft-lbs
post Feb 3, 2013 - 11:26 AM
dont do it, keep them all the same size
post Feb 4, 2013 - 3:17 AM
NOVAKx17
Joined Oct 7, '09
i just want to know why shouldn't i run it?
as long as the sizes match on the axles i don't see any ill effects happening?
NOVAKx17
post Feb 4, 2013 - 4:37 AM
delusionz
Joined Feb 11, '08
putting those smaller ones at the back is dangerous, putting them at the front will make the car handle like ****.
thats the ill effects, but do whatever, its your car and your life.
Mike W
269awhp / 273ft-lbs
post Feb 4, 2013 - 4:41 AM
NOVAKx17
Joined Oct 7, '09
what makes it dangerous and handle like ****?
i'm not being an ass, i'm just trying to learn for my benifit...
i've driven my eclipse with different sized tires like this and didn't notice a difference at all...
NOVAKx17
post Feb 4, 2013 - 5:47 AM
delusionz
Joined Feb 11, '08
how goods your FF drifting skills?
Mike W
269awhp / 273ft-lbs
post Feb 4, 2013 - 5:55 AM
NOVAKx17
Joined Oct 7, '09
not sure of the FF part. but drifting is okay . its alot more fun/easier in a rear wheel drive like my camaro rather then my celica. but i like drifiting. in the winter. i feel like this is going to be something just to make fun of me but go ahead and continue.
NOVAKx17
post Feb 4, 2013 - 9:52 AM
mkernz22
Joined May 10, '10
From MA
If you are using it for DDing, then I don't see the big deal. Just use the same two in the front and the same two in the back.
post Feb 4, 2013 - 11:28 AM
richee3
Joined Jun 29, '08
From Denver
FF is front engine, front wheel drive. Delusionz is saying that putting the smaller tires on the rear will cause lots of unexpected oversteer.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 4, 2013 - 1:30 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
if anything have the larger (width) tires in the front.
エキサイティングカーレーシングチーム!
post Feb 4, 2013 - 3:41 PM
NOVAKx17
Joined Oct 7, '09
Okay.. thanks guys.
Yeah its just for daily driving and will only be used in the spring-fall.
I was just wondering if they will wear funny
NOVAKx17
Lo-Fi Version Time is now: February 22nd, 2025 - 7:55 AM
