> PLEASE HELP!! OBD1 car OBD2 motor, OBD1 car to OBD2 motor swap
post Feb 21, 2013 - 10:02 PM
Reimrod1994
Joined Feb 21, '13
From saskatoon
my third cylinder in my 1994 celica gt-s 2.2L only has 30psi, frown.gif so i bought a 1998 celica gt-s with the same motor (both 5sfe) my 1994 is obd1 and my 1998 is obd2, what am i going to need to change or modify to put the obd2 motor into the obd1 car? i need my car back as soon as possible i dont have a vehichle right now any help is appreciated, Thanks!
post Feb 21, 2013 - 11:49 PM
Julian_Navia
Joined Nov 10, '11
From Rockville, MD
QUOTE (Reimrod1994 @ Feb 21, 2013 - 10:02 PM) *
I would think you only need to change the frontpipe of the exhaust for one that has a hole for the 2nd o2 sensor
Dude I almost had you
post Feb 22, 2013 - 1:14 AM
Reimrod1994
Joined Feb 21, '13
From saskatoon
so you dont think i would need like an OBD jumper or anything? also my 1994 car is an american car and my 1998 is a canadian car so one has abs one doesnt, what do i have to do with that?
post Feb 22, 2013 - 1:44 AM
Julian_Navia
Joined Nov 10, '11
From Rockville, MD
QUOTE (Reimrod1994 @ Feb 22, 2013 - 2:14 AM) *
Wouldn't you be using the ecu and wiring harness that came with the engine? I don't see why you would need a jumper if you are
post Feb 22, 2013 - 3:10 AM
blackliftback
Joined Mar 1, '12
From iowa
Use the following parts from.obd1 car...
Alternator
Dizzy
Ecu
Wire harness
Header
intake manifold
Use the following from obd2 car
Longblock.
There are some plugs that wont need to be plugged in. Hence the obd2 emissions and misc
Example... crank position sensor. Its not needed when ran with obd1 ecu.
post Feb 22, 2013 - 11:48 AM
Reimrod1994
Joined Feb 21, '13
From saskatoon
so the wiring harness from the obd1 car will plug into my obd2 motor? no addapters needed? and whats a longblock? im new to this site, thanks
post Feb 23, 2013 - 11:01 AM
you will have to use the harness, ecu, and all accessories from the older motor. basicly everything with a sensor on it on the OBDI motor will be transfered to the newer motor.
it all becomes pretty easy once you have the 2 motors side by side.
longblock = just the block and head with no accessories attached.
post Feb 24, 2013 - 10:06 AM
blackliftback
Joined Mar 1, '12
From iowa
All the sensors from ur old motor onto ur new one. When you use your old distributor... it will plug into your old harness... lol same with alternator. The plug that you will have left over would he the cps( crank position sensor) obd2 has it but not obd1. If you want.... you could pull the crank pulley off and remove the cps off but theres no need for that really.
Lo-Fi Version Time is now: February 22nd, 2025 - 12:36 AM
