Check Engine Light Code 12? |
Mar 17, 2013 - 7:22 PM |
Enthusiast Joined Aug 5, '09 From West Texas, USA Currently Offline Reputation: 20 (100%) |
My check engine light came on and I tested it. I got a code 12. I've researched it a bit and I think it means that no RPM signal going from the distributor to the ECU. Is that correct? How would I fix this?
This post has been edited by 1994Celica: Mar 17, 2013 - 9:37 PM -------------------- |
Mar 17, 2013 - 10:57 PM |
Probably means the distributor has eaten itself, as that's been the case every time I've seen someone with code 12. Take off the cap and give it a look.
Mar 18, 2013 - 8:55 AM |
Enthusiast Joined Aug 1, '11 From Illinois Currently Offline Reputation: 5 (100%) |
+1. That's what it was when I had a code 12. It took out the coil as well. I was broke at the time, so I grabbed a junkyard distributor and a new coil. All was well after that. Check under the cap first as was mentioned above.
Mar 26, 2013 - 3:51 PM |
Ok I'm sure I need a distributor. Which brand should I go with Cardone or BECK/ARNLEY ?
Mar 26, 2013 - 4:45 PM |
Both are reputable brands, I suppose whichever is the cheaper of the two.
Mar 26, 2013 - 7:56 PM |
Both are reputable brands, I suppose whichever is the cheaper of the two. I thought Cardone quality has fallen? Maybe I was mistaken. -------------------- |
Mar 26, 2013 - 9:04 PM |
I haven't heard of anything. I've used both brands before with no problems.
Mar 28, 2013 - 8:56 AM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
I got a remaned Toyota from O'Relieys for pretty cheap when my dizzy pickup chewed itself up. It was under the name Import Warehouse or something like that.
This post has been edited by travisxcore: Mar 28, 2013 - 8:58 AM |
Apr 13, 2013 - 4:13 PM |
Relaxed distributor and coil, didn't shut off. Took it in and apparently it's the ecu.
Lo-Fi Version | Time is now: November 23rd, 2024 - 5:09 PM |
