rim help |
rim help |
Mar 24, 2013 - 11:17 PM |
Enthusiast Joined Nov 13, '10 From Calgary Currently Offline Reputation: 0 (0%) |
if you dont mind going to this link http://www.nlmotoring.com/XXR-535-Wheels-s/1693.htm let me know which offset/size of rim i should get and what tires would go well with them , for my gt four . thank you !
Mar 25, 2013 - 12:05 AM |
that is a decision only u can make, we cant tell u what i like, because what i like may not be what u like.
i have 16 x 8 offset 35 with 225/45/16 tires... and i like it. i went from 17 x 8 offset 45 but ull get maybe 10 different opinions right after mine. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Mar 25, 2013 - 9:36 AM |
that is a decision only u can make, we cant tell u what i like, because what i like may not be what u like. i have 16 x 8 offset 35 with 225/45/16 tires... and i like it. i went from 17 x 8 offset 45 but ull get maybe 10 different opinions right after mine. sorry maybe i wasnt clear. I know that i want 17" i just dont know which width and tire combo would make it look somewhat flush , compare to the sucked in look it has now |
Mar 25, 2013 - 10:48 AM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
http://www.6gc.net/forums/index.php?showtopic=69919
use this as a sizing guide you will need different offsets for each axle set of wheels, as the rear is more sucked in, youll need a lower offset than you will have on the front -------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 25, 2013 - 4:35 PM |
Enthusiast Joined Apr 17, '10 From Maitland, NSW Currently Offline Reputation: 3 (100%) |
Well if your going 17" you only have 7" or 8.25".
Going the 8.25" will sit real flush, but you'll need a 15mm spacer in the rear. Tyres is up to you, depends if you want a good sidewall or a stretched look, probably a 215/45 would be alright! -------------------- |
Mar 25, 2013 - 11:56 PM |
Well if your going 17" you only have 7" or 8.25". Going the 8.25" will sit real flush, but you'll need a 15mm spacer in the rear. Tyres is up to you, depends if you want a good sidewall or a stretched look, probably a 215/45 would be alright! okay thanks , what about the offsets that are available ? i think if i go 17x7 it would be +35 |
Mar 28, 2013 - 7:15 PM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Well if your going 17" you only have 7" or 8.25". Going the 8.25" will sit real flush, but you'll need a 15mm spacer in the rear. Tyres is up to you, depends if you want a good sidewall or a stretched look, probably a 215/45 would be alright! okay thanks , what about the offsets that are available ? i think if i go 17x7 it would be +35 That's the only offset they have on that link for our car? Lol. Next time when I buy wheels for my car. I'm going to try to get 8j with +25 the least and +35 the most. -------------------- |
Mar 29, 2013 - 1:30 PM |
lol no those are the choices of rims i have to choose from ,
either 17x8.25 +35 or the same but +20 which one would fit better ? |
Mar 29, 2013 - 3:01 PM |
lol no those are the choices of rims i have to choose from , either 17x8.25 +35 or the same but +20 which one would fit better ? I'd say with the 8.25, the +20 for the front is going to stick a bit so you'll probably need a fender roll and pull. Also will need stretched tires. But +20 in the rear is just about perfect. If I were you, I'd stagger them and go +35 in the front and +20 in the rear. Rather have a higher offset so you can adjust the offset by buying spacers. Best to be on the safe side than spend loads of money on a wheel that doesn't fit your car. Lol. This post has been edited by ILoveMySilly97: Mar 29, 2013 - 3:02 PM -------------------- |
Mar 29, 2013 - 4:18 PM |
i cant stagger though , its all wheel drive
i just want something that i dont need to roll anything, just bolt on and finished , it doesnt need to be perfect flush |
Mar 31, 2013 - 5:26 AM |
i cant stagger though , its all wheel drive i just want something that i dont need to roll anything, just bolt on and finished , it doesnt need to be perfect flush Oh. Then in that case. Just go with the +35. That offset won't be horrible looking. It'll be bareable. If you ever want to get that flush look then you can always buy spacers in the future. But if your car is going to be slammed or low then you'll need fender roll with both offsets because of the width. If you're on lowering springs then you should be fine. I don't know how stiff the stock gt4 shocks are but I remembered on my st204 with 17x8 +35 225/45/17 in the rear. It would rub on bumps. The best tire size for a 8.25j would but 215/45 or 225/45 for that perfect sidewall with no stretch. Plus it's a gt4 so why not go for the wider tire. Lol. -------------------- |
Mar 31, 2013 - 12:54 PM |
thanks for your help man , so 8.25 +35 running 225/45 sounds like the winner , if im correct
Mar 31, 2013 - 4:23 PM |
thanks for your help man , so 8.25 +35 running 225/45 sounds like the winner , if im correct No prob. -------------------- |
Lo-Fi Version | Time is now: November 26th, 2024 - 4:28 AM |
