![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) ![]() |
Hello my name is Teo and this is my Celica. My focus is on audio and interior/exterior changes. Hope you enjoy.
7a-fe running on LPG, the rims are 16" OZ Superleggeras ![]() ![]() I found a suitable hole to run the 0ga through the passengers side firewall. But my battery is on the drivers side. As I knew I will be upgrading my stock wire I decided to avoid running such a thick wire across the engine bay and connect it straight to the alternator. One little thing- the alternator positive bolt was a little bit short for the ring terminals at the same time. Went and bought this "tube" that is threaded on the inside. Terminal for 0ga, washer, "tube" thingy, 5ga going from alternator + to battery + ![]() Back seats be gone! ![]() Falls floor done with multiple pieces to save on material. Practically zero spend on it. ![]() Carpet ![]() The box - 1.75 cub feet, kerfed port @ 32, 1.5 inch plywood walls ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Port painted in white satin ![]() 1.75 walls ![]() ![]() ![]() Bad ass terminals ![]() ![]() ![]() ![]() Sub - Sundown Audio SA-12 , Amp SAZ-1500D ![]() ![]() This post has been edited by The_enD: Jun 26, 2014 - 4:18 AM -------------------- |
Each door will have a single 10" Neopro in a ported plywood enclosure tuned to around 60Hz. Adding fiberglass for even more strength.
Plywood ![]() Door inner cover and front baffle for the enclosure. ![]() ![]() Flushed driver ![]() ![]() Big hole for the enclosure. Door will be covered in suede. ![]() Port ![]() Assembly ![]() ![]() ![]() The flush weakened the baffle, so I added two pieces at the back of it for strength. ![]() After the glue dries I will cut it out again. ![]() Attention to details. ![]() This piece is kinda of a brake point for the to separate, so called sections of the enclosure. ![]() And the round over is here ![]() 8 clamps and left to dry. ![]() ![]() ![]() ![]() ![]() Cut them up to save some space in the front by doing some relocations. ![]() Glued back on ![]() Fiberglassed the original panel to the ported enclosures ![]() ![]() Covered some parts of the wood and fiberglass with foam for a softer feel when I cover them up. ![]() Rice ![]() ![]() Old and ugly gear ball ![]() New ![]() ![]() -------------------- |
I bought the car with the original steering replaced with a MOMO RACE and decided to keep it. The leather was in bad shape tho so:
Test piece ![]() Before ![]() ![]() ![]() What happens when your hands are slightly wet -_- ![]() Making holes, no thread in the needle ![]() First piece done ![]() Making a pattern for the more complex shapes ![]() Connection stitch with black thread. It will be will be touched more, and if it was white, after a while it was bound to get dirty. ![]() ![]() ![]() The finished product of my imagination ![]() ![]() ![]() ![]() ![]() ![]() Overall I am very please with the result. It took me around 20-24 hours of hand work, measuring, cutting, using the sewing machine, making patterns, failures, stitching. Used : white and black polyester thread, real leather from some dead animal, scissors, shaving blade, 3 needles, glue. *optional : patience, good taste, the internet ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) ![]() |
Wow! Great job on that steering wheel!
![]() I seriously need to do that..*have* some one do that to for me haha -------------------- |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) ![]() |
Excellent job on that steering wheel, must be rewarding to handle your own craftsmanship daily.
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) ![]() |
Very nice, on everything!
Liking the sound setup as well. I thought I had patience with projects but all that detail.. ![]() -------------------- ![]() 6gcHeroes:808hectortimmybatmandiegotigamak |
Enthusiast ![]() Joined Feb 18, '13 From Portland, OR Currently Offline Reputation: 3 (100%) ![]() |
Wow! Yeah that steering wheel looks professional, nice job! Looks like you have a nice setup for woodworking too!
-------------------- 1999 Celica GT Auto - GF's car
1996 4Runner SR5 5sp - Ol' Faithful 2006 Evo 9 MR - For sale 1998 Supra NA Auto very slow |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) ![]() |
I love seeing different things like this. Keep up the good work!
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Thanks, all
![]() I am currently doing 141.7dB at 35Hz. But there is a competition in a month and I am hoping for a slightly higher result. And I have an 18 inch subwoofer shipping later this year. ![]() -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) ![]() |
Awesome build dude
-------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Thanks, all ![]() I am currently doing 141.7dB at 35Hz. But there is a competition in a month and I am hoping for a slightly higher result. And I have an 18 inch subwoofer shipping later this year. ![]() Are you using the small space of the Celica to your advantage?? I'm not too into sub competitions or anything but I've briefly read about people ordering subs to match the dimensions of their car. Volumetrically, their car is the sealed box. Idk..maybe I'm making all of that up haha I thought it was a cool idea but yeah, keep up the good work ![]() -------------------- |
Awesome build dude Thanks. Thanks, all ![]() I am currently doing 141.7dB at 35Hz. But there is a competition in a month and I am hoping for a slightly higher result. And I have an 18 inch subwoofer shipping later this year. ![]() Are you using the small space of the Celica to your advantage?? I'm not too into sub competitions or anything but I've briefly read about people ordering subs to match the dimensions of their car. Volumetrically, their car is the sealed box. Idk..maybe I'm making all of that up haha I thought it was a cool idea but yeah, keep up the good work ![]() Nah, I am not that fancy, it's just my daily with a loud system in it. ![]() But a hatch works good for my purpose. When the 18 comes tho I have a plan on walling it - basically you put a wall behind(one of the six of the box) you and mount the driver and port on it. Will be nuts. -------------------- |
It's the small things.
![]() Headliner bulbs changed to LED SMD's ![]() ![]() ![]() I had a 1 meter/60 LED's strip which I cut from. Soldered and used the 3M tape on the back to attach to the inside. It was a bit time consuming, but I decided to not waste my time looking for bulbs and save some money. Under $1 upgrade. This was shot in complete darkness with no flash, the LEDs are the only light source. ![]() Next thing I did was use the same LED strip and do my license plate light. ![]() ![]() ![]() ![]() And even more lights. This is a Ultraviolet neon. You can hardy see it at day and night, but add some white to it and the effect is there. Cool with white shoes or laces. ![]() -------------------- |
Teaser on what I've been working on.
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '12 From Brisbane, Australia Currently Offline Reputation: 6 (100%) ![]() |
Interesting concept with the chairs... I haven't seen it don't like that before; can't wait to see how it turns out ![]() I love your work on the steering wheel too; looks plush ![]() -------------------- ![]() SOLD :( 1997 ST204 Celica ZR -----> See it here on 6GC! 2013 October Celica of the Month XD Now: '00 NB8B Mazda MX5 -----> See it here in off topic! |
That's a great idea, Aston Martin did it, I believe.
This post has been edited by SwissFerdi: May 6, 2013 - 6:34 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Thanks guys.
I've got quite a few interior ideas from Lamborghini. -------------------- |
Couldn't resist posting my unfinished project
![]() ![]() How would you guys like a white Toyota emblem on that headrest? ![]() -------------------- |
Enthusiast Joined May 3, '13 From Mashpee,Mass Currently Offline Reputation: 0 (0%) ![]() |
Some seriously nice work on the wheel man, impressive door setup as well. Patience is a virtue!
QUOTE Patience is a virtue! Hey, that's my moto! ![]() Thanks, man. One seat is mounted, minor things I have to touch up, but apart from that it's ready. Pics soon. -------------------- |
Lo-Fi Version | Time is now: April 29th, 2025 - 7:03 PM |
