> stock rims - what center caps fit?
post May 3, 2013 - 8:34 AM
dennll
Joined May 3, '13
From VA
Hey Folks,
New to the forum - hoping someone has already gone through this before (did a search but couldn't find anything): I've got stock alloy rims on my 96 'vert, want to know what my center cap options are. The brochure showed the ones with the Toyota symbol in the middle, but if you go to hubcaps.com, they don't show that as an option. How interchangeable are the various center caps for this type of wheel?
Thanks,
Dennis
post May 3, 2013 - 11:57 AM
cheela
Joined Feb 2, '07
From Berlin, WI
I'm not sure how interchangable they are. but I know there are some with the toyota symbol in the middle and some blank ones. I got a blank one when I bought a rim off someone on here. Might be the difference between pre-facelift(94-95) and facelift (96-99). are you missing one? i can dig up that blank one for you if you need.
post May 3, 2013 - 12:01 PM
richee3
Joined Jun 29, '08
From Denver
I believe that we have the only caps that fit our rims. I've seen similar caps on Camrys but those are larger. So far as I've ever seen, no other cap will fit.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 10, 2013 - 7:54 AM
dennll
Joined May 3, '13
From VA
QUOTE (richee3 @ May 3, 2013 - 1:01 PM) *
Thanks folks. I found a part number and put some on order. We'll see what shows up!
post May 17, 2013 - 4:00 PM
dennll
Joined May 3, '13
From VA
QUOTE (dennll @ May 10, 2013 - 8:54 AM) *
Yay, center caps arrived - brand spankin' new from Toyota, machined face with the Toyota logo! I know the OEM alloys are not the snazziest rims, but I wanted to go stock and it was a fairly cheap way to go from steel wheels to alloy! If anyone's missing a cap, the part number is 20550. You'll see other numbers out there, but they're wrong - either for the painted face wheel or a different wheel altogether.
Cheers,
Dennis
Lo-Fi Version Time is now: February 20th, 2025 - 11:29 AM
