> LED Footwells
post May 15, 2013 - 7:09 AM
Liam_c
Joined Nov 29, '12
From New Zealand
Hey guys,
I am planing to do some LED lighting in my Celica tomorrow (currently 12AM in New Zealand at the moment lol)
I have 30cm red led strips to put underneath the dash board to light up the footwells.
In my Celica, there seems to already be foot well lights there... Stock Toyota ones, which do not go. They did when i first bought the car 6 months ago, but have since stopped. They weren't very bright.
I was planning on wiring them into the pre-existing wiring for these lights, but as they don't run i need to find a way of getting them working again.
Has anyone had this issue? Or know where these wires run so i can see if the wires damaged, unpluged or a fuse is blown? Please biggrin.gif
Otherwise i will just pull the door panel off, and run them off the courtesy lights.
Cheers, Liam.
post May 15, 2013 - 7:49 AM
JoshuaM
Joined Mar 6, '12
From Brisbane, Australia
I WANT YOUR LIGHTING KIT!!!
Sorry I can't be of any more assistance, I am just jealous and have been looking for that option illumination kit tongue.gif
Btw, this is a photo of your kit out of the car if it is of any help,
It just crimps onto the door ajar signal and attaches to a positive 12v source and ground.
post May 15, 2013 - 7:54 PM
Liam_c
Joined Nov 29, '12
From New Zealand
Sweet!
I've pulled it all to bits, and i have tested both terminal sockets for the bulbs with a voltimeter. I get 11.5ish volts, but the lights do not run. When i soldered on the new LEDs to the terminal on the left hand side light, it again will not run but it has voltage...
What do i do now :S
post May 15, 2013 - 7:59 PM
JoshuaM
Joined Mar 6, '12
QUOTE (Liam_c @ May 15, 2013 - 8:54 PM) *
Sweet!
What do i do now :S
So your door ajar lights still work?
post May 17, 2013 - 4:53 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Are you sure the LEDs work? Is the LED fixture designed for 12volts?
My thinking is that most LEDs are designed for 2-4 volts so to run them on 12volts you either need resistors or you need to run the bulbs a certain way(in series). The led will burn up if it gets too much voltage.
post May 18, 2013 - 3:06 AM
Liam_c
Joined Nov 29, '12
From New Zealand
The LEDs work. I put them onto a 12v battery terminal and worked fine, and it says they are rated for 12v supply.
The door lights were working too. But the keyring around the key wasn't working either.
In the end the whole lot got re-wired and the JDM footwell lights got pulled out. The wiring was all twisted and munted.
post May 18, 2013 - 4:14 AM
JoshuaM
Joined Mar 6, '12
So did you keep the original wiring unit or start from scratch? Shoot us a pm if you pulled the JDM unit out and don't want it smile.gif
This post has been edited by JoshuaM: May 18, 2013 - 4:15 AM
post May 18, 2013 - 4:41 AM
Liam_c
Joined Nov 29, '12
From New Zealand
QUOTE (JoshuaM @ May 18, 2013 - 4:14 AM) *
The actual box control unit was screwed. So it would of had no use. It has new wiring, but it uses the same connectors from the JDM box to the actual power input.
The JDM lighting was very dim even when it decided it wanted to work. I'd suggest you'd make your own as well. Except use a similar hulk green colour to the JDM one. It just used T5 bulbs with a green cap, you could probably get an LED strip from Aliexpess or you could just get the same bulbs and connectors and wire it in yourself?
post May 18, 2013 - 4:53 AM
Box
Joined Feb 23, '12
From Warrior, AL
I was waiting for you to say in the end it was the fuse you never bothered checking... tongue.gif
2001 Miata LS 5-speed
post May 18, 2013 - 7:02 AM
JoshuaM
Joined Mar 6, '12
QUOTE (Liam_c @ May 18, 2013 - 4:41 AM) *
Ahh okay. Did you wire up your new ones on a time delay, or are they just with the door ajar lights? I want mine on a delay since I want that ignition ring light! tongue.gif (And I knew I could make the circuit myself... I am a second year electrical engineering student... I just wanted moar JDM bits tongue.gif)
I am planning to get some warm white bulbs like the stock dome lights... I think it will look more classy than blue LED's which is what I have in the rest of my dash smile.gif
post May 18, 2013 - 7:11 AM
Liam_c
Joined Nov 29, '12
From New Zealand
QUOTE (JoshuaM @ May 18, 2013 - 7:02 AM) *
Yeah no time delay. But thats something for another day. I wonder if i could get one from a wreaker or even get one outta of something else. I used to have a Primera (yes i know, a primera) and that had time delays, and my leds used to fade out, and it looked so good
Lo-Fi Version Time is now: November 29th, 2024 - 1:50 AM
