> buying beams.
post Jun 10, 2013 - 3:28 PM
mi645
Joined May 23, '12
From northridge,CA
purchasing a beams I was wondering if anyone would mind sharing some links or ideas where to buy one?
which would you trust? which exactly would you buy please take youre time into this I really need help finding a trusted seller as I already tried purchasing one locally and it had everything lied about.
post Jun 10, 2013 - 3:38 PM
why not V6, im not far from you and i have a V6 on hand, much cheaper than a BEAMS
post Jun 10, 2013 - 9:12 PM
Box
Joined Feb 23, '12
From Warrior, AL
2001 Miata LS 5-speed
post Jun 10, 2013 - 9:56 PM
ok, since you live in california, i better recommend you get a v6 swap. you wont pass smog. Having said that, if you are desperate for a beams...
1. cheaper is not always better
2. Local is not always better.
1st most important things to look for: functional vvti controller, b pipe, and maf and oem airbox... Im telling you sourcing these parts are a bitch.
2nd most important: an LSD tranny, and or the complete set of axles. U can use a non lsd with regular axles, but lsd with the beams axles are better.
3rd. not so important. but ok to have are goodies attached. these are the double piston brakes, and or cool manifold exhausts that are rare... anything else you see in the pic, that the seller is unaware... (lol)
where?
I got mine from ebay, but i bought after it was discussed it was going to be a complete engine. If they give the 30 day start up warranty, they cant honor if you cant start. meaning vvti controller, maf and airbox need to be in the swap.
i looked for several weeks on ebay, and got one with free shipping.
but why go to the hassle of all this for 200 hp, the beams is cool engine,but i feel the celica needs more.... I may put mine for sale in several months.
Go for a V6, in california, that is the only legal way to go
post Jun 10, 2013 - 11:03 PM
mi645
Joined May 23, '12
From northridge,CA
Ok beams it is! Lol!!!!!!!!!
It's fine about smog I work at Toyota if I really want I can put my 5s back on and smog it but I'm going to track tr car I went the beams not the v6 I want the high rev potential and I've been a big fan of 3s I also get oem beams parts from Japan thru my dealer
post Jun 11, 2013 - 2:12 AM
ok then...good luck. its an easy swap.
post Jun 12, 2013 - 2:36 PM
mi645
Joined May 23, '12
From northridge,CA
So Im looking for beams I find like 210 psi or 220 psi which would u choose and why? Because spec says should e 198.7
post Jun 12, 2013 - 6:10 PM
Rusty
Joined Nov 5, '07
From New Zealand
sounds like a SXE10 blacktop beams which is rwd, not going to fit/work
post Jun 12, 2013 - 6:17 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
B18c engines which have same compression as our but they say they are supposed ti have 220 across the board if that helps...
post Jun 13, 2013 - 12:07 AM
mi645
Joined May 23, '12
From northridge,CA
Talking about red top I found 3 and compression results on 1 of them was 210 psi all across and the other was 220 all across which 1 would u take?
post Jun 13, 2013 - 1:07 AM
Box
Joined Feb 23, '12
From Warrior, AL
Found this: http://www.beams-redtop.com/redspecs.htm
Between the two I'd say the one with least miles on it and/or whichever looks cleaner.
post Jun 13, 2013 - 4:50 AM
^^^ that
post Jun 13, 2013 - 11:45 AM
BonzaiCelica
Joined Apr 24, '08
QUOTE (Box @ Jun 13, 2013 - 1:07 AM) *
this is already stickied http://www.6gc.net/forums/index.php?showtopic=61995&hl
post Jun 13, 2013 - 7:40 PM
BonzaiCelica
Joined Apr 24, '08
So will a 5sfe pressure plate fit onto beams flywheel
post Jun 13, 2013 - 7:51 PM
BonzaiCelica
Joined Apr 24, '08
woops double post
This post has been edited by BonzaiCelica: Jun 14, 2013 - 11:58 AM
post Jun 13, 2013 - 10:14 PM
aspen
Joined Nov 29, '07
From Colorado
As far as I know, it should - that is, running the BEAMS flywheel (which is insanely light) and a 5S-FE clutch and disk....
Let me check to make sure it lines up here....Yes, it fits.
2019 M2, 2005 S2000, 1997 4Runne
post Jun 14, 2013 - 11:21 AM
mi645
Joined May 23, '12
From northridge,CA
thank you all wish me luck im going to pick up a beams today in about 5 hours after work =] so I need advice now on b4 I swap it what should I replace to make life easier recommendations are accepted =] thank you everyone and no hate on the v6 guys a v6 would be awesome but I simply want the 3sge and (hint I was about to purchase an st162 1988 gts with a first gen stock 3sge in it also found a few alltracs that model which I love st165 but they all need a ton of work. if any beams owners need parts let me know im a Toyota tech my dealer is ok with me to order oem parts.
post Jun 15, 2013 - 10:48 AM
mi645
Joined May 23, '12
From northridge,CA
http://item.mobileweb.ebay.com/viewitem?it...nid=31090876158
Local If good how much do u Guys think I should offer and can anyone tell if this is from st202 Celica or sw20 mr2? I need harness to be Celica please.! smile.gif and what's missing from what u guys can tell like sensor wise
post Jun 15, 2013 - 11:34 AM
Antz5SFE
Joined Jan 3, '12
looks like it's from a SS-II. & it's missing the intake box, MAF sensor, & b-pipe. listen to these guys when they tell you it is your BEST BET to buy a COMPLETE swap. including the things i just listed. try to find one with LSD too. i wish i did more reading before i bought mine.
post Jun 15, 2013 - 11:36 AM
richee3
Joined Jun 29, '08
From Denver
It's definitely from a late spec ST202. I notice that the O2 sensor is missing. They're a pain to get Stateside but any generic Denso 4 wire O2 sensor can be wired in. The BEAMS ECU ignores it anyway. Looks like the fuel line is cut, so you'll have to splice your 5S fuel line to the BEAMS fuel line. Njccmd has pictures of that in his progress thread. The TPS usually gets broken during shipping, and I see that one is still good. You'll want to order a new thermostat and valve cover gasket right away, as well as clean the ISCV. Those are the biggest trouble spots on a BEAMS when everyone first picks them up. I'm on my 4th thermostat (not my engine's fault). I'm browsing from my phone so the pictures aren't very big, but I do t see the MAF either. I've bought a brand new one for $100.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: January 9th, 2025 - 2:14 PM
