Automatic shift Overdrive wire termination, Where is the wire for the automatic shift knob plugged in? |
Jun 29, 2013 - 7:05 PM |
Enthusiast Joined Jun 29, '13 From NewHampshire Currently Offline Reputation: 0 (0%) |
Ok I needed to fix the slider on my automatic transmission as it was trashed by the previous owner.
He also cut the overdrive wire from the shift knob, lost the original shift knob, and yanked the wires for the OD out apparently. I want to replace the shift knob and restore it with a original unit with the OD switch but don't not know where the OD wire gets plugged in. Does any one have a picture of this location? Or know where it is? JD |
Jun 30, 2013 - 12:41 AM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
The shifter assembly has 2 plugs running to it from the ECU (I'd imagine their part of the trans harness).
The smaller one is for the OD (towards the front on the driver side of the shifter assembly) The other plugs into the shift lock ecu (towards back on the drivers side, across from the handbrank on the shifter assembly). My wires are still back there cause I never bothered to delete them after the swap so I can grab pictures if you want but I don't have the shifter assembly any more to show you where they plug into. |
Lo-Fi Version | Time is now: December 1st, 2024 - 10:34 PM |
