How to fix the EGR code!! |
Jul 4, 2013 - 7:44 PM |
Enthusiast Joined Jun 28, '13 From México Currently Offline Reputation: 0 (0%) |
I just make the diagnosis and it gives me this EGR code... 7 flashes + 1 flash and is the only problem that the car has!! Don't know where to start!!!
Jul 4, 2013 - 9:22 PM |
Shove a paper clip into the harness of the EGR temp sensor, gets rid of the code.
It's either caused by: EGR temperature sensor EGR valve EGR modulator EGR solenoid Have to test them all individually to find the cause of the malfunction. -------------------- 2001 Miata LS 5-speed
Jul 4, 2013 - 10:05 PM |
Any
threads? |
Jul 4, 2013 - 10:52 PM |
i got lucky for a few years now, i pulled out the EGR filter and cleaned it, erased the code, and never came back.
Jul 4, 2013 - 11:56 PM |
I alredy done that.... The filter is brand new and i erased the code after 25 min came back on....I think that I will remove TB and clean it! 8)!
Jul 5, 2013 - 12:57 AM |
EGR gets some gunk inside it too.
Jul 9, 2013 - 7:19 PM |
Enthusiast Joined Jul 8, '13 From Atlanta Currently Offline Reputation: 0 (0%) |
I used to have an EGR code too. I ended up fixing it by noticing a hose was disconnected under the hood. I think the previous owner must have taken off one the EGR system hoses.
Jul 9, 2013 - 10:57 PM |
Welll... The cable is in place!!! I think but after I clean the T.B the engine light turns off... The after an hour lights back again!! I think if I remove the T.B and clean everything this problem will be fix!!.... I hope!!
Jul 10, 2013 - 12:23 AM |
The way the code triggers is once it's up to temp and hits 55+ mph, if things aren't right it stores the code temporarily. The next time you drive and hit 55+ if the problem still exists it throws the code and triggers the light. The only thing that'll cause the EGR code are the things I mentioned in my first post.
This post has been edited by Box: Jul 10, 2013 - 12:23 AM -------------------- 2001 Miata LS 5-speed
Lo-Fi Version | Time is now: December 4th, 2024 - 10:19 AM |
