stock alarm, is this where its located? |
Jul 12, 2013 - 1:32 PM |
Enthusiast Joined Feb 28, '03 From So-Cal Currently Offline Reputation: 1 (100%) |
i need some input on this. i have an alarm installed already on my car. when i purchased the car the previous owner had eliminated the clutch pedal switch and put it on a switch. i forgot about the switch being mounted in the den under the stereo and when i pulled the stereo out i yanked the switch off. i reconnected the wires and it worked for a little bit. now im having problems of when i try to start the car i get nothing but a clicking sound of a relay of some sort.
the clicking is coming from this module. what is this? thanks in advance guys! |
Jul 12, 2013 - 2:12 PM |
That's your engine ECU. The OEM RS3000 alarm is a small black box underneath the driver seat.
Jul 12, 2013 - 3:49 PM |
Enthusiast Joined Apr 22, '10 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Mounted next to the ecu is the circuit opening relay, this will be what is clicking. The reason will be low power and when you try to crank the enginecover the relay chatters due to not enough power to keep the relay energised due to the draw to the starter motor.
Brad |
Jul 12, 2013 - 4:58 PM |
so would i need a battery change?
Jul 12, 2013 - 5:14 PM |
Start with trying jump start first over 90% of my tech calls are car battery issues, I run a car alarm company here in New Zealand
Jul 14, 2013 - 10:41 PM |
Ain't that the flux capacitor?
Lo-Fi Version | Time is now: November 28th, 2024 - 6:44 PM |
