FS: AC Delco inner tie rod ends. |
Aug 9, 2013 - 4:31 PM |
I have two extra 15 mm wheel spacers I don't need. I do not have any extra studs to go with them, only the spacers. Open to offers.
AC Delco inner tie rod ends. Brand new in box, never opened. Rock Auto apparently sent a set to me and a set to my parents' house. Cost $80 shipped, don't need them at all. Not looking to get my money back. My loss is your gain. This post has been edited by richee3: Oct 19, 2013 - 8:19 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 9, 2013 - 4:55 PM |
Enthusiast Joined Jan 19, '09 From Texas Currently Offline Reputation: 12 (100%) |
PM'd
Aug 9, 2013 - 5:08 PM |
Enthusiast Joined Apr 15, '13 From Winnipeg, MB, Canada Currently Offline Reputation: 14 (100%) |
-------------------- 2007 Impreza 2.5i - Daily
1994 Camry - Sold 1994 Celica - Sold :( Click here to see my progress thread! |
Aug 9, 2013 - 7:34 PM |
PM'd Replied. Don't really know much about spacers lol but do you think I could use them on my back wheels? Yes. You'd just need to buy some extended wheel studs to go with these spacers since I don't have them. 10 mm isn't a huge spacer but they make a noticeable difference. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 10, 2013 - 12:49 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Don't really know much about spacers lol but do you think I could use them on my back wheels? If you want to flush them out. I think you'll need 25mm+ spacers. Lol. You're better off with buying adapters/spacers. So you wouldn't need to install extended lug nuts and you can also get the ones that converts from 5x100 to 5x114. -------------------- |
Aug 10, 2013 - 9:08 AM |
If you want to flush them out. I think you'll need 25mm+ spacers. Lol. You're better off with buying adapters/spacers. So you wouldn't need to install extended lug nuts and you can also get the ones that converts from 5x100 to 5x114. Any specific reason to convert to 5x114? My wheels are 5 bolt universal so I technically could -------------------- 2007 Impreza 2.5i - Daily
Aug 10, 2013 - 1:13 PM |
Since your wheels are universal then if I were I would get the adapter. 5x100 is really limited to aftermarket wheels. 5x114 opens your wheel market, double than what you'll find in 5x100 market. Lol. Its really hard to find a perfect set of wheels for 5x100. Like for me. I want the xxr 535 but they don't come in a low enough offset or wide enough rim for me to flush out with minimal use of spacers. So.....i might end up going with the 527 since they're universal.
Aug 23, 2013 - 3:45 PM |
Bump. Also adding a Kirkosarus poly motor mount insert. Pictures still coming, if I can ever remember.
Aug 23, 2013 - 4:13 PM |
Enthusiast Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) |
Which mount does it fit?
Aug 23, 2013 - 4:18 PM |
Front and I think the rear too but don't quote me on that. I've had a front insert for over a year now and just bought a brand new pair so I can get the rear insert. I think the front and rear inserts are identical but they may not be.
Aug 23, 2013 - 5:00 PM |
I would need the rear over the front with the 1MZ. I'll research it.
Aug 24, 2013 - 4:27 PM |
Like I said, I think the front and rear are interchangeable but I'll be able to confirm that in a couple of days. Unless someone jumps in here and confirms it first.
Pics of the spacers! Pics of the mount insert coming in the next couple of days. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 26, 2013 - 12:26 PM |
Confirmed that the front and rear mount inserts are definitely different. Since I only need the rear, here are pics of the front:
Aug 26, 2013 - 3:15 PM |
Enthusiast Joined Nov 13, '10 From Greenville, SC Currently Offline Reputation: 50 (100%) |
Man, I've been wondering how just one insert was beneficial. I had this idea that it was a single one, and not a set! Hahahaha! This makes so much more sense!
Aug 26, 2013 - 4:03 PM |
Man, I've been wondering how just one insert was beneficial. I had this idea that it was a single one, and not a set! Hahahaha! This makes so much more sense! It is beneficial to have just one. It's that much less flex in the motor mounts. Granted, having a pair is more beneficial, but having just a single insert will still help. I've just had the front insert for the last year and I'm getting ready to add my new rear insert. Since I had to order a new pair to get a rear mount, I have an extra front mount that I don't need. It's the same insert in the pictures, just two different angles. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 26, 2013 - 11:46 PM |
Enthusiast Joined Nov 23, '12 From Troy, IL Currently Offline Reputation: 5 (100%) |
Please confirm the spacers are 10mm not 15 (picture looked a little thick).
Would you take $20 for spacers? I already have some 10mm longer studs (uninstalled). |
Aug 27, 2013 - 2:23 AM |
I'll grab a tape measure tomorrow. I bought these from Diegohiga who said they were 15 mm. They are the same thickness as my 10 mm spacers I have on the car now. $20 will work though.
Aug 27, 2013 - 8:53 PM |
From the sounds of it, I have a spare set of AC Delco inner tie rod ends at my parents's house. Anybody need them? They cost $80 shipped from Rock Auto and I have no use for them. I have a set here and a set there, apparently.
Sep 1, 2013 - 6:52 PM |
Front mount insert sold, added brand new in box inner tie rod ends.
Sep 1, 2013 - 7:50 PM |
Enthusiast Joined Sep 13, '10 From Austin, tx Currently Offline Reputation: 3 (100%) |
Lo-Fi Version | Time is now: December 1st, 2024 - 5:24 PM |
