> TOM'S 3S-GE N/A, 231 horsepower
post Aug 15, 2013 - 10:44 PM
azian_advanced
Joined Apr 18, '05
From Calgary
I just saw this on the TOM'S racing page and never heard of this engine ever existing.
Complete Engine 2.2 Liter 3S-G
- MSRP/ 1,365,000 Yen (1,300,000 Yen w/o tax) ~ (Price will vary due to customization) Product made upon purchase
- Specs/ Displacement 2,253cc, Bore x Stroke 87.0x94.8, Max Power 172kW(235ps)@6,800rpm, Max Torque 255Nm(26.0kgf-m)@4,400rpm
- Components/ 2.2 Liter Forged Pistons, 2.2 Liter Crankshaft, F3 Gasket, F3 Camshafts (IN&EX 256), TEC2 Computer, Lightened Flywheel
- Vehicle Application/ MR2 (1989~1997 SW20 equipped with 3SGE), Other Vehicles Equipped with 3SGE (Excludes VVT-I engines)
For Further Details (TEL:0550-89-8397)
~$14,000 USD
Source: http://www.tomsracing.co.jp/products/parts...s.php?mprID=285
post Aug 15, 2013 - 10:51 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Seeing that price is probably why it isn't in anyones car lol.
post Aug 16, 2013 - 1:20 AM
Rusty
Joined Nov 5, '07
From New Zealand
can get finer details if people want them?
post Aug 16, 2013 - 2:28 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (RabidTRD @ Aug 15, 2013 - 10:51 PM) *
Indeed. I can think of so many other things to buy that'd be better. redface.gif
2001 Miata LS 5-speed
post Aug 16, 2013 - 8:17 AM
cheela
Joined Feb 2, '07
From Berlin, WI
at that price you can convert your car to a legit GT-four.
post Aug 16, 2013 - 9:48 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
QUOTE (cheela @ Aug 16, 2013 - 9:17 AM) *
Or pay someone off to import one in really good condition lol. Unless by convert you mean converting those little metal plates lol.
post Aug 16, 2013 - 10:57 AM
Syaoran
Joined Jan 4, '12
From US
So a high compression 5S-GE N/A with cams and useless exhaust-cam VVT-i does 231 flywheel HP and that's impressive?
Ni**a plz... Get a 3SGTE head, slap it on your 5S, get 3rd gen 3SGE cams and 11:1 comp pistons and you'll probably have 231 wheel horsepower with a proper tune.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Aug 16, 2013 - 6:30 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Syaoran @ Aug 16, 2013 - 8:57 AM) *
That's exactly what came in mind once I saw the 2.2. Lol. The 5s block can provide a lot of power. It's just the fe head that makes it lack power.
post Aug 16, 2013 - 6:42 PM
bnr32celica
Joined Jan 16, '12
From 860, ct
Fappin' all day, fappin' all night.
I NEED this. Who needs their inheritance early? I'll do it!
post Aug 19, 2013 - 5:48 PM
Red123
Joined Oct 25, '11
From Tbilisi
QUOTE (cheela @ Aug 16, 2013 - 8:17 AM) *
I always wanted to ask that question.
Usually how much $ is necessary to convert celi to a full GT-Four in USA?
Thanks
post Aug 19, 2013 - 8:01 PM
Rusty
Joined Nov 5, '07
From New Zealand
Pistons & crank developed from the F3, JTCC.
2,253cc, Φ87mm 94.8mm. CR unknown
the 5S-FE is
2,164cc Φ87.1mm 90.9mm
In & Ex cams: 256deg, 10.5mm lift
Factory:
In: 252deg, 9.8mm lift
Ex: 240deg, 8.2mm lift
Not a whole lot bigger, though it isn't higher reving. Would have been nice to see the specs of '@ 1mm valve lift' instead of advertised duration.
Also that price is from when it first came out in the 90's, so price has probably dropped.
It doesn't have any VVT-I. Seems a bit pointless sourcing a gen 3 3SGTE head and then 3SGE cams. Just get the gen 3 3S-GE head with the cams in it already, as the heads are pretty much identical.
post Aug 20, 2013 - 12:37 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Rusty @ Aug 19, 2013 - 9:01 PM) *
the 5S-FE is
Factory:
2nd gen GTE head, 3rd gen cams (very common mod) is what I meant. It's a lot cheaper than sourcing a 3rd gen 3S-GE head in the US...
post Aug 22, 2013 - 11:06 AM
Red123
Joined Oct 25, '11
From Tbilisi
QUOTE (Red123 @ Aug 19, 2013 - 5:48 PM) *
Thanks
post Aug 30, 2013 - 1:59 AM
CAcelica29
Joined Aug 26, '11
From ventura, ca
how feasible is it to really build a performance hybrid version of the 5sfe? just curious as to what the reality of it being built is.
post Aug 30, 2013 - 10:10 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (CAcelica29 @ Aug 30, 2013 - 2:59 AM) *
Very feasible. Nobody has done it because it's an all-custom build. 5S-FE block and crank, 3SGTE head, hybrid pistons, rods...etc. The power will really be at 11.5:1 compression, high lift cams (10mm lift minimum) with decent duration, etc...
post Aug 30, 2013 - 4:26 PM
Rusty
Joined Nov 5, '07
From New Zealand
I know putting GE cams into a GTE head is pretty well known, but still seems odd to me to use the older gen 2 head, with the valve/shim set up (but if you're putting new cams in then you're most likely going to address this) and the ports which had tvis and poor flow from memory.
22#deg @ 1mm valve lift for the cams, maybe a staggered set up for more mid range.
another thing is a reverse head set up...
300hp NA 2L 3S-GE 8,500rpm rev limit
reversed head
dry sump
slide throttle body
6 Speed Sequential DBR box with electronic flat shift
Carbon/carbon clutch
post Sep 6, 2013 - 1:20 PM
TRDweaponX
Joined Aug 4, '11
From Texarkana Texas
Thats a sick set up!^^^
post Sep 6, 2013 - 1:41 PM
CAcelica29
Joined Aug 26, '11
From ventura, ca
so basically it hasnt been done because a 3s swap is alot easier.
post Sep 6, 2013 - 5:17 PM
Rusty
Joined Nov 5, '07
From New Zealand
it is a 3S...
post Sep 15, 2013 - 12:39 AM
6strngs
Joined May 12, '06
From Wilmington, NC
I doubt you could get your hands on one of these engines if you tried. They were most likely built for race teams that wanted the best of the best. Sure you could build a hybrid engine for cheaper, but you're comparing a budget garage build to a fully built stroker engine made by a high-end brand name company.
This post has been edited by 6strngs: Sep 15, 2013 - 12:39 AM
Lo-Fi Version Time is now: January 10th, 2025 - 5:43 AM
