> How to get to your fuel pump, Fuel pump
post Aug 30, 2013 - 9:59 PM
RavenAegis45
Joined Jun 25, '08
From CA
So after my minor breakdown whilst i was tearing much of my car apart I took pictures of how to remove your fuel pump which is a lot easier than I had believed it to be so hopefully this helps someone down the road
So first of all you'll have to remove your seats, surprisingly there are only 4, 12mm bolts holding the upper portions of the seats on, located at the very bottom when you fold your seat down, they'll be easy to get to once you lift up the carpet covering them, there are 2 on each side of the folding portions of the seats
So once the 4 bolts have been removed the upper seat cushions literally slide right off, the lower seat cushions are only held in place by 2 small hooks that go into these sockets
once the rear seats are removed you'll see the access panel for the fuel pump it has 4 small Phillips head screws holding it down
oh and don't forget to look for loose change under your seats while your at it wink.gif
Who said working on your car doesn't pay
Moving on you'll see the fuel pump bracket, connector and fuel lines under the access panel be sure to disconnect the electrical connector to give you more room to work
For the rubber return line you can just use a small set of channel locks to remove the clamp and slide it off, but for the other fuel line with the fittings you'll need a 19mm open end wrench and a 14mm flare nut wrench
If your unlucky like me and your fittings are pretty rusted then get a can of this stuff, PB penetrating catalyst or some other penetrating oil
I covered the electrical connector with a rag so as not to get any penetrating oil in it and I basically drenched the nut every couple of minutes before going at it again
Once the fitting is off you can take off the small bolts surrounding the fuel pump bracket, they're 8mm with a phillips head so you can break them loose with a socket and take them off easily with a screwdriver or however you want
And with the fuel lines out of the way and the bolts off the whole assembly will come out fairly easily and you can check your pump and strainer, sorry but I forgot to get pictures of the pump itself haha rolleyes.gif
post Aug 31, 2013 - 9:08 AM
mgnt232
Joined Mar 16, '09
great thread, you should ask rusty to sticky it somewhere
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Aug 31, 2013 - 9:35 AM
Syaoran
Joined Jan 4, '12
From US
A picture of the assembly would've been nice, but good job! Will find this useful when I replace my pump.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
Lo-Fi Version Time is now: December 12th, 2024 - 2:44 PM
