94 Gt Parking Brake problem, Shoe hold-down spring cup problems |
Sep 5, 2013 - 8:23 PM |
Enthusiast Joined Aug 8, '13 From Vermont Currently Offline Reputation: 0 (0%) |
After disassembling the parking brake, and beginning to reinstall new shoes and hardware, I cannot slide in the rear shoe between the shoe holddown spring cup and the backing plate.
The diagram shows you squeezing the spring by hand but I just can't seem to do it that way. Can I get some suggestions, my car is sitting up on Jack right now so it would help very much -------------------- 1994 Celica GT Hatchback 109,xxx mi
1997 Celica GT Convertible LTD Edition 118,xxx mi |
Sep 6, 2013 - 10:09 AM |
Bump
Can someone please help me?!?!? I'm still up on jacks and this is keeping me from even getting the wheel back on to drive to a shop. Please, I'm in dire need if your help Thanks -------------------- 1994 Celica GT Hatchback 109,xxx mi
Sep 7, 2013 - 7:53 AM |
Enthusiast Joined Oct 25, '12 From Pennsylvania Currently Offline Reputation: 0 (0%) |
You have to remove the pin that holds that the spring holds in place. Just wiggle it out of the back of the plate, slide the shoes in, and reinstall the pins. Put your finger around the back of the plate to hold the pin in place while you install the spring and its retaining cup. The spring tension is pretty light, and a 90 degree twist of the cup will lock it in place. If you can't install them, remove all the loose bits, and drive it to a shop.
Sep 23, 2013 - 8:17 PM |
Enthusiast Joined Aug 27, '13 From Pittsburgh Currently Offline Reputation: 0 (0%) |
Can somebody point me in the direction of the diagram? I've got a gt with rear disc that I need to rebuild the parking brakes on.
Oct 21, 2013 - 12:44 AM |
Enthusiast Joined Jan 12, '09 From State College, PA Currently Offline Reputation: 1 (100%) |
Can somebody point me in the direction of the diagram? I've got a gt with rear disc that I need to rebuild the parking brakes on. http://bgbonline.celicatech.com/94_6gmanua...ke%20system.pdf That's about the best I've found. |
Lo-Fi Version | Time is now: November 26th, 2024 - 1:29 PM |
