The first Audi look LED-tails |
Sep 17, 2013 - 3:35 PM |
Enthusiast Joined Mar 12, '10 From netherlands Currently Offline Reputation: 0 (0%) |
Because everyone has the kouki tail lights, i'd like to try something new. Drilling 80 holes with 80 leds, and 10 hours work on 1 taillight, is this the result. This week i try to build the unit on the car, and then we will see how it look like. |
Sep 17, 2013 - 3:58 PM |
Enthusiast Joined Jan 13, '12 From Georgia Currently Offline Reputation: 3 (100%) |
Looks good what's the final plan... Anything between the original lights? Or are you planning for those to be the running lights?
-------------------- 97 Celica GT liftback DD/ project
96 corolla back up DD |
Sep 17, 2013 - 8:22 PM |
Enthusiast Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
Very nice! Does the bumpy texture of the lens distort the lines at all and do all 80 LEDs have seperate resistors?
Sep 17, 2013 - 8:55 PM |
Enthusiast Joined Aug 4, '06 From Chicagoland Currently Offline Reputation: 9 (100%) |
Looks cool! I've thought about doing this, but around each of the tail lamp features.....
Have you figured out how you're going to handle moisture/water intrusion issues? -------------------- ~bloodMoney
Sep 17, 2013 - 9:47 PM |
Looks pretty good.
Sep 18, 2013 - 10:04 AM |
@ toyota123: Here in the Netherlands we dont have to put on the lights 24/7. So i put them on when its dark. They replace the normal backlights. But i keep the original brakinglight.
@Special Edy: I drilled the holes in the backside of the tab, and thats just next to the bumpy texture, see the next pictures below.Yupp every led got a own resistor. 80 leds---> 80 resistors. I create groups of 20. @ Bloodmoney: I am very creative with silicone |
Sep 18, 2013 - 10:16 AM |
Enthusiast Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
Nice. Im glad there is someone else who is being creative with the rear lights.
Sep 18, 2013 - 10:23 AM |
Here you see the silicone, the leds and the resistors. And WHERE I drilled the holes.
At the front side, the light comes out of the thin dark line |
Sep 18, 2013 - 11:54 AM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Should have used SMD LEDs, so much easier to mount, a lot less soldering, low profile, cheap... list goes on.
Sep 18, 2013 - 1:54 PM |
Would've been kind of hard to use SMD's in this instance. For one the curvature of the line would've made it a pain, and the fact the holes were drilled out and the LED's inserted would be more difficult with a SMD. Unless you baked open the light and could get SMD strips to fit into the crevice he used, that would be a little easier overall. The only thing I would've done differently on this install would've been to make a lot of arrays in series and wire them in parallel to greatly reduce the amount of resistors and soldering needed.
Looks cool and has a lot of possibilities. Would work great as a stop light or as a tail light. Kind of like the idea of using it as a stop light, really get people's attention. This post has been edited by Box: Sep 18, 2013 - 1:58 PM -------------------- 2001 Miata LS 5-speed
Sep 18, 2013 - 2:24 PM |
Would've been kind of hard to use SMD's in this instance. For one the curvature of the line would've made it a pain, and the fact the holes were drilled out and the LED's inserted would be more difficult with a SMD. Unless you baked open the light and could get SMD strips to fit into the crevice he used, that would be a little easier overall. The only thing I would've done differently on this install would've been to make a lot of arrays in series and wire them in parallel to greatly reduce the amount of resistors and soldering needed. Looks cool and has a lot of possibilities. Would work great as a stop light or as a tail light. Kind of like the idea of using it as a stop light, really get people's attention. The SMD's can be cut every 5cm or every 3 LEDs (depends on the type tho) and then without any problems just connected to + and - wires. Additionally you can cut those 3 in and arrange them in whatever fashion as long as you keep the circuit the same as before (+-+-+-). They are a lot smaller so the hole drilled for them will be too. They could of been mounted the same way he did with encased LEDs, just not taking up that much space and time soldering each. -------------------- |
Sep 18, 2013 - 4:24 PM |
The last time I saw a SMD LED strip the way they're spaced it would've needed cut after every diode for the curves on the light. I like the flexibility offered by individual LED's(rather SMD or traditional), but I also like the convenience of SMD LED strips for covering large areas instantly. Haven't looked lately, but it'd be nice to find a tightly spaced SMD LED strip.
Sep 19, 2013 - 2:36 AM |
I bought a long roll or flexible LED strip which can be cut to any length in when I was planning on doing something similar. Personally I would have removed the lense and put a stip in for a cleaner look but this method would be easier.
Oct 1, 2013 - 4:30 PM |
Enthusiast Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Innovative! I like!
Oct 4, 2013 - 7:24 PM |
Enthusiast Joined Jun 3, '13 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
keen to see some photos of it fitted once its done. Looks pretty cool so far but I agree if I was attempt this I would use strip LED's
-------------------- 1997 White ST202
Oct 4, 2013 - 7:59 PM |
Enthusiast Joined Jul 27, '06 From Soda Currently Offline Reputation: 9 (91%) |
I must admit, it looks damn good! Cant wait to see the finished product.
Lo-Fi Version | Time is now: November 29th, 2024 - 8:03 PM |
