FS: 3rd gen 3SGE Curren motor SOLD, SOLD |
Feb 9, 2014 - 12:59 AM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
3rd gen 3SGE motor that was used for spares and mock-up of a couple custom turbo kits.
The head is was ran in one of my Celicas for around 2 years until it was swapped out for a ported head. Includes: Valve train, gears, camshafts - untouched since the head was pulled - all 3SGE parts. Top feed fuel rail and stock 3SGE injectors (295cc - I ran 550cc injectors without problems). Side feed intake manifold with throttle body - ACIS may be welded shut as it created havoc under boost. valve cover, alternator bracket and hangers present, alternator Extra bosses have been drilled / tapped to match the turbo exhaust manifold coolant elbow is either from a Curren or Celica. The block appears to be in good shape; no obvious signs of problems. I pulled the lower oil pan off and everything looks like the factory original parts. Includes: Rods / Crank / pistons Oil pump / oil pans / oil pickup Water pump / lines / thermostat housing - There's no power steering pump and the pulley on the A/C pump was mangled during shipping. I travel to Chicago quite often and occasionally to Detroit, so I can deliver / meet in this area to avoid shipping. Otherwise will need to be sent via freight. Will post pics later today. This post has been edited by scothaniel: Mar 20, 2014 - 10:26 AM -------------------- Scott
West Michigan |
Feb 9, 2014 - 7:50 AM |
Enthusiast Joined Jan 27, '14 From Fort Wayne IN Currently Offline Reputation: 0 (50%) |
Pm'ed
-------------------- 94 Teal GT-DD 223,915 miles SOLD
99 WHT GT- Race car! Or just AutoX Car getting rebuilt then susp and turbo! |
Feb 9, 2014 - 9:34 AM |
With custom td05 turbo kit :) -------------------- Scott
West Michigan |
Mar 9, 2014 - 7:21 PM |
Enthusiast Joined Sep 16, '10 From Warren, MI Currently Offline Reputation: 0 (0%) |
Which part of Michigan are you from?????
Mar 10, 2014 - 7:48 PM |
Currently Grand Rapids
West Michigan |
Lo-Fi Version | Time is now: November 29th, 2024 - 7:37 AM |
