> Door Card inserts
post Feb 10, 2014 - 2:37 PM
enderswift
Joined Jul 12, '08
Can anyone share their experience removing cloth upholstery from their door-card inserts? Mine are ruined and I'd like to know how to pull them off without damaging the vinyl underneath.
post Feb 10, 2014 - 2:38 PM
richee3
Joined Jun 29, '08
From Denver
I was able to pull mine off easily then remove the glue with acetone.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 10, 2014 - 3:09 PM
yellowchinaman
Joined Aug 11, '08
From London
The card behind isnt so easily ruined. Just rip it off.
post Feb 10, 2014 - 3:22 PM
cheela
Joined Feb 2, '07
From Berlin, WI
it's just cloth with adhesive that isn't that strong. I've ripped a pair off of a wrecked GT at the junkyard.
underneath was just fine. lol.
post Feb 10, 2014 - 3:54 PM
pull it...
i used mine to trace in leather
then when u spray adhesive
then carefully trim the leather
post Feb 10, 2014 - 4:15 PM
enderswift
Joined Jul 12, '08
Thanks for the replies and pictures guys thumbsup.gif . I figured it would be easy but I've broken enough things in the past to motivate a question haha.
post Feb 10, 2014 - 5:15 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
If you're really worried, I found isopropyl alchohol and non-acetone fingernail polish remover both worked well at softening the adhesive. For the most part you don't have to worry, unless the vinyl behind the hard is cracked -- most likely around the edge of the card where the vinyl is pressed into that tight crevice.
Lo-Fi Version Time is now: February 17th, 2025 - 4:57 AM
