> Quick fuel pump question!
post Mar 6, 2014 - 8:07 AM
R4R44V15
Joined Oct 20, '11
From Colorado
Right, so I'm pretty sure I need to replace my fuel pump on my '97 GT. I'd like to just go ahead and get a Walbro, but I don't want to use a universal since I'm afraid the electrical connectors won't match up. Is there a Walbro aside from the universal that will just fit straight away that doesn't require any modification to the existing connection? Or if anybody knows more about the connection there and knows if they are universal as well, let me know. Any info appreciated!
Oh, and one more question while I'm posting... this has only happened a couple times so far, but maybe some of you would know something about it. There have been a couple mornings where I will start my car and it will be very rough, almost "puttering", and fluctuation between right around 800-900rpm. This has happened both when it is really cold outside, and really warm outside, so I don't think the weather is really a factor. Either way, if I give it gas, the rpms go up like normal, but when they fall, the car will die. Though once the car is running like that for a bit, it like... awakens. Haha. Any help or insight on that one?
post Mar 6, 2014 - 9:15 AM
DaTerrorist
Joined Dec 19, '11
From billings mt
http://www.6gc.net/forums/index.php?showtopic=41314&hl
post Mar 6, 2014 - 11:12 AM
VavAlephVav
Joined Dec 3, '13
From Missourah
have you replaced the fuel filter anytime recently?
also the Idle Air Control IAC could be old/dirty/unplugged
Bust a Deal; Face the Wheel.
post Mar 7, 2014 - 4:25 AM
R4R44V15
Joined Oct 20, '11
From Colorado
QUOTE (VavAlephVav @ Mar 6, 2014 - 12:12 PM) *
Thank you both. I was thinking about going ahead and doing the fuel filter and the fuel pump (it squeals when it starts up) this coming week. Will check the IAC as well.
post Mar 7, 2014 - 9:45 AM
mkernz22
Joined May 10, '10
From MA
Probably have to clean out the iac. Tends to get a lot of junk in there over time and effects the idle. I know I need to do mine, but until it starts stalling, I refuse haha
Lo-Fi Version Time is now: November 25th, 2024 - 6:19 AM
