> What is this....
post Mar 6, 2014 - 3:57 PM
Zephri
Joined May 4, '13
From Indianapolis
What is this connector attached to the dipstick supposed to be for, I'm guessing it goes to an oil level sensor or something?
There is no harness anywhere that plugs into it, it doesn't affect anything I'm really just curious.
This post has been edited by Zephri: Mar 6, 2014 - 4:47 PM
post Mar 6, 2014 - 4:15 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
QUOTE (Zephri @ Mar 6, 2014 - 12:57 PM) *
You talking about that ground wire?
post Mar 6, 2014 - 4:48 PM
Zephri
Joined May 4, '13
From Indianapolis
I knew I should of circled it..... There, all done! =D
This post has been edited by Zephri: Mar 6, 2014 - 4:51 PM
post Mar 6, 2014 - 4:56 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
I think its the crankshaft position sensor but I could be wrong.
You should put your celica's year and model in your signature so we know what engine you have.
I think the crankshaft position sensor is used on the 96 or 97 and newer 7A-FE.
Since your's is a 95 that means that this engine was swapped in from a newer celica or corolla. You dont need the crankshaft position sensor or have a pigtail for it because the 95 ST utilizes a camshaft position sensor inside the distributor which carries out the exact same function, fuel injector and ignitiin timing.
This post has been edited by Special_Edy: Mar 6, 2014 - 5:05 PM
post Mar 6, 2014 - 5:11 PM
Zephri
Joined May 4, '13
From Indianapolis
Yeah I probably should put what I have in my sig line.
Anywho thanks for the answer, your deduction is most likely correct, this car has a salvage title for a "flooded" car and was bought by my brother years ago from Northside Imports. I have no doubt the engine is a swap coming from that place, since they tend to deal in salvaged cars.
Lo-Fi Version Time is now: November 25th, 2024 - 6:40 AM
