car stalls help please!, stalling car |
Apr 3, 2014 - 6:55 PM |
Enthusiast Joined Jul 4, '13 From Cypress ,TX Currently Offline Reputation: 0 (0%) |
Ok so I have a 95 celica gt , and it stalled on me for the first time. I was at a drive tru engine sounding good I stepped on the gas and it instantly died no hesitation tried to turn it on the starter worl but engine would not turn. I tried 3 times before I called a tow truck. In the evening I tried again and it turned on so I left it running to see if it would stall and sure enough 20-25 minutes later same thing did not start till after a hour. Can u guys tell me what can cause this by the way I have a check engine code 12.
Apr 4, 2014 - 10:28 AM |
Any one has a clue ?
Apr 4, 2014 - 9:53 PM |
Enthusiast Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
See if the CEL illuminates when the key is turned to on with the engine not running (while the car is acting up)
Check for spark, you can ground a plug wire or spray starter fluid into the intake to verify this. Test the primary and secondary resistance on the coil with a multimeter. When coils fail they will sometimes intermittently fail when they get hot. Check your ground wires You can use a noid light on an injector to check the ECU, and a fuel pressure tester to check the fuel pump. Both these tools will be available for loan at your local discount autoparts store. Of course all checks should be while the symptoms are present. |
Apr 4, 2014 - 10:05 PM |
Thanks for your response edy. I had a trusted mechanic come by since I gave up and it turn out to be a bad distrubutor.
Apr 4, 2014 - 10:34 PM |
Enthusiast Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Funny....cause I got a code 12 today too. The readings were not good between ne and g-.
Apr 4, 2014 - 11:19 PM |
Funny....cause I got a code 12 today too. The readings were not good between ne and g-. those are both in the distributor, id start there -------------------- 2001 Celica GT-S Turbo
Apr 4, 2014 - 11:23 PM |
When my mechanic check all the sensors were ok. ignition coil ok , icm ok he said something bout the distributor so I purchased a new one. The code instantly disappear and my car has not stalled so far.
Apr 5, 2014 - 3:43 AM |
Funny....cause I got a code 12 today too. The readings were not good between ne and g-. Yup its the pickup in the distributor. They should be marked in the diagnostic port. If you set your multimeter to measure continuity you should get a beeping sound when the engine is rotating. Im living off of North 820 and 35 now, I have time off at the beginning of the week if you need a hand. @medina95gt Hmm, it sounded like a faulty ignition coil. Autozone or OReilly should of been able to test the coil for you with a multimeter, you can also check the magnetic pickup with a multimeter. Must be all the rain we got. This post has been edited by Special_Edy: Apr 5, 2014 - 3:46 AM |
Apr 5, 2014 - 8:06 AM |
Actually I already replaced it from my pile of parts.
Apr 5, 2014 - 11:42 AM |
Actually coils were ok o believe it was some thing in the actual distributor
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:25 PM |
