> Headers
post Apr 15, 2014 - 3:54 AM
Kirby
Joined Apr 7, '14
Just purchased some headers off ebay, engine is a 2.2 5sfe. What's a good way to bypass the cel? Tune, or others?
This post has been edited by Kirby: Apr 15, 2014 - 3:55 AM
post Apr 15, 2014 - 7:55 AM
PegGTS
Joined Apr 15, '13
From Winnipeg, MB, Canada
Header*
I'm not 100% sure because I just had the shop that was doing my exhaust do the header as well, but I think as long as you have the O2 sensors plugged in you shouldn't get a CEL
2007 Impreza 2.5i - Daily
1994 Camry - Sold
1994 Celica - Sold :(
Click here to see my progress thread!
post Apr 15, 2014 - 1:33 PM
what header did you get? does it have the bung for the O2 sensor?
post Apr 15, 2014 - 1:36 PM
Kirby
Joined Apr 7, '14
QUOTE (Smaay @ Apr 15, 2014 - 2:33 PM) *
Ended up getting this header http://www.ebay.com/itm/120774006458
(manza) and yes looks like there is a bung for the O2 sensor.
post Apr 15, 2014 - 1:38 PM
PegGTS
Joined Apr 15, '13
I have that one and there definitely is a bung
1994 Camry - Sold
post Apr 15, 2014 - 2:10 PM
Kirby
Joined Apr 7, '14
QUOTE (PegGTS @ Apr 15, 2014 - 2:38 PM) *
So no cel? Just direct fit O2 sensor in bung and good to go??
post Apr 15, 2014 - 2:43 PM
PegGTS
Joined Apr 15, '13
QUOTE (Kirby @ Apr 15, 2014 - 1:10 PM) *
As far as I know yes, but like I said I'm not 100% sure because I just had the shop do the header while they were doing the exhaust
1994 Camry - Sold
post Apr 15, 2014 - 2:53 PM
Kirby
Joined Apr 7, '14
QUOTE (PegGTS @ Apr 15, 2014 - 3:43 PM) *
Ah I see, well thanks...wish there was more info on our cars. Been searching and can't find anything.
post Apr 15, 2014 - 4:00 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
Are you OBDI or OBDII? Also are you Cali emissions or Federal?
post Apr 15, 2014 - 5:07 PM
Wraithner1
Joined Aug 30, '13
From vinton, ohio
obi II and i bought the same headers. and that answered my q before i could ask thanks lol
post Apr 15, 2014 - 7:20 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
I mean you could try un-plugging it. I did that for my dual o2 sensor setup on my Cali emissions and it didn't throw a CEL.
post Apr 23, 2014 - 10:54 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Quick question. Do I need to remove the alternator to remove the stock manifold? Or should I be fine? On the 5th Gen my friend had to move the alternator a bit.
post Apr 23, 2014 - 11:06 PM
Wraithner1
Joined Aug 30, '13
From vinton, ohio
QUOTE (ILoveMySilly97 @ Apr 23, 2014 - 11:54 PM) *
nope i didnt
post Apr 23, 2014 - 11:18 PM
Poonicus
Joined Apr 24, '13
From Tomball, TX
No to put the header on you just have to take the heat shield off and the header is going to hang once you get all the bolts off but just kinda move it over to the right and it should slide right off once you clear the studs at least that's how I changed mine.
"As a professor of science, I assure you we did, in fact, evolve from filthy monkey-men." -Prof. Farnsworth
post Apr 24, 2014 - 2:40 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Poonicus @ Apr 23, 2014 - 9:18 PM) *
Awesome. thanks. Ima install mine next week.
post Apr 24, 2014 - 10:02 AM
i think i has to take tension off the alternator belt, remove the belt, then rotate the alternator up to get enough clearance to a stud bolt. I didnt have to take it off, but i had to move it up out of the way
post Apr 24, 2014 - 11:50 AM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Smaay @ Apr 24, 2014 - 8:02 AM) *
Bummer, I didn't want to do that. Hopefully I'll get away with out moving the alternator.
post May 2, 2014 - 5:14 PM
Kirby
Joined Apr 7, '14
Update: I got away without touching the alternator…just took a little bit of creativity. And it's running great with the 2nd (bottom o2 sensor unplugged) just left the bolt in there that it came with and torqued it. Pretty easy install if you have the right tools.
post May 2, 2014 - 7:15 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Kirby @ May 2, 2014 - 3:14 PM) *
Same here. A problem I ran into was the upstream o2 studs were too wide so the stock o2 flange holes couldn't go through. So I had to hacksaw on side so it'll slide in.
post May 21, 2014 - 6:27 PM
Kirby
Joined Apr 7, '14
QUOTE (ILoveMySilly97 @ May 2, 2014 - 8:15 PM) *
I thought I had a similar problem..wouldn't quite fit right at first with the given o2 sensor gasket…had to re-use the old one to make it work.
Lo-Fi Version Time is now: November 26th, 2024 - 8:32 AM
