Stripping down a 3sgte transmission |
May 13, 2014 - 9:28 AM |
Enthusiast Joined Apr 19, '08 From Norway Currently Offline Reputation: 0 (0%) |
I have a complete 3sgte engine still attached to the subframe and transmission, which i have to strip down so i can ship the transmission. I have never done this before, so i just wonder if there is anything i should be aware of. Or if i can simply start pulling things apart. For instance, i dont know what to expect when i detach the motor from the gearbox. Any oil i have to remove? Some pictures or a quick how-to would be greatly appreciated.
I have this: And i want this: This post has been edited by skogs: May 13, 2014 - 9:38 AM |
May 13, 2014 - 9:39 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
Gear oil will only come from where the axles are inserted into the transmission (and the drain/fill plug of course).
May 13, 2014 - 10:19 AM |
Enthusiast Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Ah so much fun to be had there.
Really, its just taking things off 1 by 1, and then taking all the bolts from the housing. Try not to wreck the spline. I had my engine set on a hoist, I just lifted it a little bit, and pulled it off by hand. Its heavy, may need some help. |
May 13, 2014 - 2:20 PM |
Enthusiast Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
With manual transmissions, once you remove all the bellhousing bolts the transmission will simply slide away from the engine until the clutch comes off the splined input shaft in the center of the transmission. You will probably want to try to support the engine and transmission as best as possible to prevent any damage to the input shaft and keep the transmission from falling to the floor.
Im not sure how much the E154 weighs, but with the smaller S54 in the GT I was able to lift the transmission in and out with my shoulder, once on jackstands and once on a car lift. With two people it shouldnt be a problem. Another tip for removing and especially installing a transmission on most vehicles is to use the starter bolts (theyre usually 3 or 4 inches long) and thread these bolts into two opposite sides of the bellhousing before you seperate it from the engine. This way, when you pry the engine/tranny apart and the transmission comes off the input shaft, the starter bolts will keep the transmission supported and lined up with the engine. Once clear of the input shaft, remove the starter bolts and lower the tranny to the floor. |
May 13, 2014 - 2:50 PM |
Thanks a lot, this really helps!
So i should drain the gear oil before removing the axles then. And be careful not to wreck the spine when pulling the engine from the transmission. The starter bolts is a good tip! |
May 13, 2014 - 5:11 PM |
dont worry about the spline, its beefy and wont get damaged. there are several smaller bracket that bolt the AWD trans to the block, so you will have to remove them as well. there is also an oil cooler attached to the trans so you will have to disconnect that. once everything is unbolted they will start to separate. the AWD trans is EFFING HEAVY so watch your toes!!!!
Lo-Fi Version | Time is now: November 26th, 2024 - 11:05 PM |
