> How to: One solution to the ST passenger motor mount, for 3sge, 3sgte and beams
post May 16, 2014 - 6:44 AM
I have seen several solutions, and i figured out a simple one for my liking, if you have access to a welder.
I used grade 8 nuts. These nuts are spot welded to the frame anyway, and the frame is what supports the engine weight. the previous owner had already drilled the holes for me, I just figured how to spot weld a nut in there, so when you tighten it, the bolt wont move. The bolt does not hold any weight.
so I welded two nuts, to a flange...
make sure your bolt is center and is appropiate
I secured the flange with the bolt into the right position, to center it and to get it tight to the frame, where it would rest forever...
once welded properly, i cut the excess metal..
did the second one and filled up the holes again, to prevent mice from finding a nest..
and shaved, and had the bolts ready to be used..
those nuts dont move and you can torque the bolts appropiately... I was in a hurry, so i could have welded the holes.... but oh well.
This is not the best approach, but just one of many...
post May 16, 2014 - 8:28 AM
Wow, this is actually a pretty good idea!
I'm going to have to steal it when I drop my motor in, probably should do this before I paint my engine bay laugh.gif
post May 16, 2014 - 1:53 PM
The_enD
Joined Apr 12, '13
From Bulgaria
Nicely done!
FS thread : Custom Celica parts made to order + more
Click the image to visit my FB page
Lo-Fi Version Time is now: November 26th, 2024 - 7:42 PM
