> FS Random 205 Parts + Alltrac parts
post Jun 3, 2014 - 9:20 PM
alltracman78
Joined Aug 9, '06
From Ma
I've got to get rid of more of my spare parts, so this is your chance to snap them up. smile.gif
Prices don't include shipping.
If you need closer/better pictures of something, feel free to ask.
I'll do my best to ship in flat rate boxes [if that's cheapest], and shipping can obviously be combined.
Paypal is fine, or you can mail me a check/MO.
If you're interested in something I wouldn't suggest waiting around on it, they're not going to be on here for that long.
Gen II.
2 transmission lower covers. $10 each.
Plate between engine and transmission. $14
2 inner timing belt covers. $20 each
2 outer upper timing belt covers. None of the holes are broken. On one the plastic is in a little worse shape. Better one $35, other $25.
Inner REAR fender liner for L side, covers the gas tank fill tube. Fits 90-91 only. $30
Engine oil dipstick, end has blue silicone tubing over it. $8
2 alternator cooling ducts. $10 each
Shifter base. $10
92/93 stock shifter [shorter than 90/91]. $20
US spec intake manifold, has port for EGR. Perfect if you need your swap to pass emissions. One of the bolt holes for the TB the threads are damaged, it can definitely be helicoiled. $40
Set of red Samco silicone radiator hoses. Dirty but in great shape, no rips/tears. $30
IC coupler for TB to air to air IC, no rips/tears. $10
2 turbo to IC couplers, both soft, no rips/tears. $10 each
Regular AFM, works fine, un modded/un touched. $45
Pwr steering pump bracket, no rust/almost no rust. $10
Alternator bracket for 7 BOLT MANIFOLD ONLY! Will not work with 9 bolt manifold. No rust/almost no rust. $10
Intake tubing. I don't have any lower elbows, only upper and the metal elbow.
1 upper elbow + metal elbow + Vacuum line. $10
1 upper elbow + metal elbow. $9
1 upper elbow. $7
1 metal elbow. $5
Plastic clips for front of USDM 185 bumper cover. Can't find the Toyota P#. $5
185 Plastic gas tank cover. Has multiple cracks in the plastic but will still go on vehicle fine. $25
205 Stuff.
Flexible trans cooler oil line. From trans to under radiator only. $20
Lower radiator hose + clamps. Still flexible, no rips/tears. $7
L & R OUTER tie rods + castle nuts. Boots in good shape. $20 each
Intake tube. Not sure if it's 100% of the intake tubing or not. No rips/tears. $20
Front speed sensor. Wire is cut, don't remember which side it is. $5
Passenger side front CV shaft. Missing outer joint. Has good inner joint and outer boot. $20
post Jun 5, 2014 - 10:21 PM
alltracman78
Joined Aug 9, '06
From Ma
Ok, parts SOLD so far are
1 transmission lower plate
Transmission/engine plate
both outer timing covers
1 alternator cooling duct
Samco hoses
IC to TB coupler
CV shaft
post Jun 6, 2014 - 8:44 PM
alltracman78
Joined Aug 9, '06
From Ma
205 Intake & trans cooler lines SOLD.
post Jun 8, 2014 - 4:59 AM
timdog1720
Joined Mar 4, '10
From Bronx NY
1 upper elbow + metal elbow $9
1 upper elbow. $7
and speed sensor $5
pm'ed
Always fast and going for the look......
post Jun 8, 2014 - 12:57 PM
Arturio55
Joined Mar 6, '13
From New jersey
Price for AFM, alternator and power steering brackets?
QUOTE (Azncelica @ Mar 4, 2012 - 11:43 PM) *
I started with what I know to do, I swap engine into my car, I knew it was too much work to make it a AWD. I kept it FWD. Went to take a crack at doing the wiring conversion. Than, I realize, shoot, this is out of my league.
post Jun 8, 2014 - 9:25 PM
alltracman78
Joined Aug 9, '06
From Ma
Replied to both of you.
This post has been edited by alltracman78: Jun 8, 2014 - 9:26 PM
post Jun 8, 2014 - 11:00 PM
those transmission covers, the lowers, both shipped to 38305?
post Jun 9, 2014 - 9:41 AM
Arturio55
Joined Mar 6, '13
From New jersey
If this greedy guy ^^ doesn't take both I'll also take a transmission cover, along with engine backing plate (between engine and tranny)
post Jun 9, 2014 - 10:02 PM
alltracman78
Joined Aug 9, '06
From Ma
Trans plates are sold, sorry.
Lo-Fi Version Time is now: November 29th, 2024 - 3:55 PM
