Upgrading to a 3sgte |
Jun 25, 2014 - 11:46 AM |
Enthusiast Joined Apr 17, '13 From Beaufort, SC Currently Offline Reputation: 0 (0%) |
Hopefully I will be upgrading to a 3sgte by next year and need to know what all should be planning to buy for? I got a 94 Celica GT. I'll be buy the Motor
Transmission, ECU, Distributor, Alternator, Complete Intake and Exhaust Manifold, A/C Power Steering Pump, All Brakets and Sensors, Engine Wiring Harness, All required Cables, and Turbo... Other than an upgraded fuel pump (recommendations on that) and pressure gauges for interior, what else should I be purchasing? |
Jun 25, 2014 - 2:01 PM |
a lottery ticket.
Jun 25, 2014 - 6:26 PM |
Enthusiast Joined May 13, '14 From Savannah, GA Currently Offline Reputation: 0 (0%) |
Hopefully I will be upgrading to a 3sgte by next year and need to know what all should be planning to buy for? I got a 94 Celica GT. I'll be buy the Motor Transmission, ECU, Distributor, Alternator, Complete Intake and Exhaust Manifold, A/C Power Steering Pump, All Brakets and Sensors, Engine Wiring Harness, All required Cables, and Turbo... Other than an upgraded fuel pump (recommendations on that) and pressure gauges for interior, what else should I be purchasing? Manual boost controller...or an electronic one if your already spending the money. |
Jun 25, 2014 - 6:54 PM |
Save some money and just get the complete engine, ECU, and harness. You can't use the transmission that comes with it anyway as it's AWD, the S54 in the GT will work just fine with an upgraded clutch and stock power levels.
Jun 26, 2014 - 12:31 AM |
yes the AWD trans can be used, it will only cost you a differential and cover plate
Jun 26, 2014 - 2:32 AM |
I guess you'd more or less make it an E153 then.
Lo-Fi Version | Time is now: December 1st, 2024 - 9:51 PM |
