Motor Mount Part Numbers, Looking for some clarification. |
Aug 7, 2014 - 6:33 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I'm in the market for some new motor mounts, and after searching on toyodiy, I can't exactly pinpoint which mounts I need. The car is a 95 Celica GTS, 5SFE, Manual trans, and I'm looking to replace the front mount, as well as the rear dreaded trans mount.
After Looking on toyodiy, I've come up with the following part numbers: BRACKET, ENGINE MOUNTING, FRONT(FOR TRANSVERSE ENGINE): 12311-74180 BRACKET, ENGINE MOUNTING, REAR(FOR TRANSVERSE ENGINE): 12321-74320 Source: http://www.toyodiy.com/parts/p_U_1995_TOYO...LMGKK_1107.html However, there's also a bunch of other things listed under Engine Mounting, like Insulator assemblies and Stabilizers. And after searching on Rock Auto, they have front and rear mounts for a standard transmission from multiple brand names, however none seem to match with the above listed mounts. Can anyone point me in the right direction as to what I need? Also, is there a brand that should be preferred over another? Or would it be best to go with an OEM mount from toyota? Thanks in advance! -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 7, 2014 - 7:33 PM |
check rockauto if it comes out to be cheaper they have both front and rear.
but i don't know how toyodiy comes up for you. i've registered an account to toyodiy, thinking the diagrams would pop up but it never did. so know i go here: http://toyotamarket.ru/jp/252170/003/1/1107/1/12371A/ you also forgot to check this sticky. this is where i ordered my front one and many various oem parts due to discount and free shipping over $75 i believe. but only one of those employee who can get you the discount works there now. Forgot which it is i can check my email if you like. the last time i ordered anything was a year ago... http://www.6gc.net/forums/index.php?showtopic=77353 This post has been edited by BonzaiCelica: Aug 7, 2014 - 7:35 PM -------------------- Group buy to replicate Narrow E series transaxle parts
Aug 8, 2014 - 4:06 PM |
Right: 12362-74430 Left: 12372-74450 -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 9, 2014 - 11:43 AM |
Right: 12362-74430 Left: 12372-74450 Thanks for the link, but I can't seems to make any sense of it haha. Which would be the front and rear mounts? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 12, 2014 - 8:48 AM |
Bump, anyone?
Aug 12, 2014 - 9:10 AM |
well what mount do you need? do you need the bracket that bolts to the transmission or the mount that bolts to the body of the car? I posted the part numbers for all the mounts in this thread
http://www.6gc.net/forums/index.php?showtopic=92362 Part numbers for the mounts are: Front Trans Mount 12311-74180 Front Body Mount 12360-74050 Drivers Trans Mount 12325-74240 Drivers Body Mount 12372-74450 Rear Trans Mount 12321-74320 Rear body Mount 12371-74410 These are not cheap from the dealer, so i suggest you plan ahead and find them from a junkyard or on ebay -------------------- 2001 Celica GT-S Turbo
Aug 12, 2014 - 4:44 PM |
well what mount do you need? do you need the bracket that bolts to the transmission or the mount that bolts to the body of the car? I posted the part numbers for all the mounts in this thread http://www.6gc.net/forums/index.php?showtopic=92362 Part numbers for the mounts are: Front Trans Mount 12311-74180 Front Body Mount 12360-74050 Drivers Trans Mount 12325-74240 Drivers Body Mount 12372-74450 Rear Trans Mount 12321-74320 Rear body Mount 12371-74410 These are not cheap from the dealer, so i suggest you plan ahead and find them from a junkyard or on ebay I'm not sure to be honest. I had my car at shop for other things, and had some speculation that mounts needed to be done and he confirmed that was the case. Im going to crawl under there now and take a look, as i didnt realize there was two parts to each, I thought it was just one mount that bolted to the body. Would these part numbers include the rubber as well, or strictly just the metal mounting brackets? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 12, 2014 - 7:40 PM |
Took a look under the car, and the rubber has slight cracking on them, but all of the brackets are intact and not cracked, from what I could tell.
So from the image posted above, I'd gather the mounts I need are: Front: 12360 Rear: 12371a I managed to find these on Rock Auto, for about $60 for front and $20 rear. Also checked the link to Conicelli Toyota Parts and it came out to be 83 for the front and 60 for the rear. Would it be worth while to spend the extra couple of bucks to get the OEM toyota ones, or should I just get the rock auto aftermarket ones? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 12, 2014 - 8:29 PM |
Those are just reference numbers for the actual part number.
12360 INSULATOR ASSY, ENGINE MOUNTING, FRONT 12360-74050 1 $118.53 12371A INSULATOR, ENGINE MOUNTING, REAR 12371-74410 1 $87.97 12372A INSULATOR, ENGINE MOUNTING, LH(FOR TRANSVERSE ENGINE) 12372-74450 1 $133.56 12362 INSULATOR, ENGINE MOUNTING, RH(FOR TRANSVERSE ENGINE) 12362-74430 TYPE A 1 $190.69 12362-74460 TYPE B 1 $164.91 Those numbers are all from ToyoDIY for my '98 ST204. I had a type A passenger side mount. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Aug 13, 2014 - 10:01 AM |
Those are just reference numbers for the actual part number. 12360 INSULATOR ASSY, ENGINE MOUNTING, FRONT 12360-74050 1 $118.53 12371A INSULATOR, ENGINE MOUNTING, REAR 12371-74410 1 $87.97 12372A INSULATOR, ENGINE MOUNTING, LH(FOR TRANSVERSE ENGINE) 12372-74450 1 $133.56 12362 INSULATOR, ENGINE MOUNTING, RH(FOR TRANSVERSE ENGINE) 12362-74430 TYPE A 1 $190.69 12362-74460 TYPE B 1 $164.91 Those numbers are all from ToyoDIY for my '98 ST204. I had a type A passenger side mount. Perfect, this is what I found too and its starting to make sense now. Thanks a lot. So the full part number would be the bottom, next to the price? Did you end up doing with OEM parts, or Aftermarket? -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 13, 2014 - 11:16 AM |
Yep, the part numbers are the 10 digit numbers on the bottom. I ended up ordering an aftermarket rear mount and passenger mount from RockAuto, replaced my front mount with a mount from one of the BEAMS I ordered, and added poly inserts to the front and rear. Driver side mount is still original, shame on me.
Aug 13, 2014 - 12:56 PM |
Yep, the part numbers are the 10 digit numbers on the bottom. I ended up ordering an aftermarket rear mount and passenger mount from RockAuto, replaced my front mount with a mount from one of the BEAMS I ordered, and added poly inserts to the front and rear. Driver side mount is still original, shame on me. I was going to do the same, just ignore the side mount for now. How'd you like the poly mount? I've been debating, but my car will never see a track so I was leaning towards just new mounts. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 13, 2014 - 3:33 PM |
Dustin hooked me up on my front mount, so I went with it and ordered a rear. It definitely stiffens things up quite a bit. It's not bad for a DD but vibrates a bit more than I'd like. If I had to do it over again, I'd just go with replacement mounts but what I want out of my car is different than what 90% of members on 6gc want.
Aug 14, 2014 - 6:46 PM |
Dustin hooked me up on my front mount, so I went with it and ordered a rear. It definitely stiffens things up quite a bit. It's not bad for a DD but vibrates a bit more than I'd like. If I had to do it over again, I'd just go with replacement mounts but what I want out of my car is different than what 90% of members on 6gc want. Ah yea, well thanks for the info. I think I'm just going to order OEM mounts, rather than aftermarket. And skip on the poly for now. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Aug 19, 2014 - 10:23 AM |
Well I priced them out and they're about 60 and 80 from the US dealer, and 160 and 200 from the Local dealer (Canada).
Looks like i'll be ordering from the US.. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:02 PM |
