> Fog lights wiring help, Factory wiring
post Nov 22, 2014 - 4:03 PM
toyota123
Joined Jan 13, '12
From Georgia
So after days of searching and what I thought was correct wiring I have no power to fogs. I'm trying to install ffogs from a 97 GT into a 95GT.
I have not had any luck finding the factory wiring diagram. I'm putting them in my wife's celica and want them to work with the combo switch I already have it re wired and working correctly. Just no power to the fogs. Please help
97 Celica GT liftback DD/ project
96 corolla back up DD
post Nov 22, 2014 - 4:11 PM
i can scan the page here. but use this in the mean time..
http://www.6gc.net/forums/index.php?showtopic=38656
post Nov 22, 2014 - 7:45 PM
toyota123
Joined Jan 13, '12
From Georgia
QUOTE (njccmd2002 @ Nov 22, 2014 - 4:11 PM) *
I read that one a couple of times. Here is what I've done
I ran the green/black from combo to top of relay.
Blue/red from left of relay to fuse panel.
Red/white from right of relay to Junction that goes through the firewall
Solid red with single grey stamp also goes to Junction through the firewall
The red/white and solid red are what are getting me. What exactly are these going to? Kind of hard to explainbbecauseI ddidn't pull the wires in the order I installed them and there was about a week of time between pulling them and trying to put them back. The interior wiring was done pull a wire and put it where it goes so I'm pretty sure those are all right. It's just I'm lost on what is going out.
post Nov 22, 2014 - 8:04 PM
best i could do with camera. should guide you... faily simple
post Nov 22, 2014 - 8:11 PM
toyota123
Joined Jan 13, '12
From Georgia
That actually helps a lot my biggest issue was that solid red it goes from one silver striptto a double silver when it ties into the headlight. I'll try again tomorrow and post my findings.
Thanks a ton
post Nov 23, 2014 - 5:17 PM
ive been looking for the pdf version of the book for a while..
post Nov 23, 2014 - 7:26 PM
toyota123
Joined Jan 13, '12
From Georgia
QUOTE (njccmd2002 @ Nov 23, 2014 - 5:17 PM) *
What'stthe name I'll see if I can hel. LLooks like a lot of useful information there
post Nov 24, 2014 - 12:44 PM
toyota123
Joined Jan 13, '12
From Georgia
Mission successful! Just need to figure out where I want to run the power wire (solid red) permanently
post Nov 24, 2014 - 1:06 PM
in the diagram, to the 15 amps fuse from headlight..
post Nov 24, 2014 - 5:55 PM
toyota123
Joined Jan 13, '12
From Georgia
QUOTE (njccmd2002 @ Nov 24, 2014 - 1:06 PM) *
I ran it to the battery. Either way if they aren't turned they stay on.
post Nov 24, 2014 - 7:23 PM
here you go
https://share.acrobat.com/adc/document.do?d...4a-56ed1b61eaa6
download it, its for a 95, but it will be deleted on jan 15
Lo-Fi Version Time is now: February 17th, 2025 - 7:03 AM
