engine trouble, anyone no what the problem is? |
Feb 10, 2004 - 10:15 AM |
Enthusiast Joined Aug 4, '03 From Surrey Currently Offline Reputation: 0 (0%) |
well I was driving steadily on the motorway at about 70mph and all of a sudden its like someone is playing with my throttle, I get a sudden drop in power for a split second then the power is back. feels really weird like a kerking feel.
Does anyone know what the problem might be or has anyone had the same problem. many thanks |
Feb 10, 2004 - 3:09 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
could be a plug in your exaust. if you exaust is old and rusted or just a ****ty muffler, pieces of metal inside the muffler break off and restrict the flow of exhaust here and there. If this is the problem, it'll happen more then once.
Feb 11, 2004 - 5:01 PM |
Enthusiast Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
I need more info. Here's a start. It almost sounds like you are running off of 3 cylinders. Sometimes plug wires go bad. When your car is running and acting like this, lift your hood and remove a plug wire. The car should about stall. Plug the wire back in quickly. If you remove a plug wire and you see no change, that cylinder is not firing or not getting fuel. Could be the plug, plug wire or injector. Inspect your plug wires first.
This post has been edited by celica3sgte: Feb 11, 2004 - 7:14 PM |
Lo-Fi Version | Time is now: November 28th, 2024 - 1:58 PM |
