> no place on inatke for mass air flow sensor, there is no where to fit it
post Feb 11, 2004 - 4:12 PM
belizecelica
Joined Feb 4, '04
From Tampa
Installed a modified civic short ram intake on an ST but i noticed a sensor on the stock intake. There is no place to fit on the new intake. What should i do? I was told to stick a resistor in the plugs. Will this take care of the problen??
post Feb 11, 2004 - 4:14 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
drill a hole and stick the grommet from the stock intake box in the hole and push in the temp sensor.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 11, 2004 - 5:02 PM
SpedToe169
From Dallas, Tx
Yup. And like 97sccelica said, its not a mass airflow sensor, its and intake temperature sensor.
post Feb 11, 2004 - 9:07 PM
belizecelica
Joined Feb 4, '04
From Tampa
thanks for the info, i was going to drill a hole to make the sensor fit, but what about the resistor fix?? Thats what i have in there now and it seems to work fine. Is this bad for the engine???
post Feb 11, 2004 - 9:32 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
its a hack mod,
its best for the ecu to kow the temp of the air going into the engine.
get the sensor back in, but for now, your ok
post Feb 12, 2004 - 9:46 AM
SpedToe169
From Dallas, Tx
Yeah, definitely drop the resistor. I doubt it will on a 7a because of the way the ecu works, but it very well could do damage to your engine.
post Feb 12, 2004 - 1:21 PM
toyotaspeed_90
Joined Jan 22, '04
From bellingham, WA
in the future just buy an intake for a 93-97 corolla, lol
post Feb 12, 2004 - 1:54 PM
jpodstawa
Joined Feb 5, '04
From Alhambra, Illinois
I had the same problem the other day. Just drill a hole and put it in!
post Feb 12, 2004 - 4:01 PM
blkGT
Joined Jun 10, '03
From FL
why did i not have one of those confused.gif all my friends were suprised i didnt and frankly so was i
post Feb 12, 2004 - 4:59 PM
Anub1s
Joined Nov 27, '03
QUOTE (blkGT @ Feb 12, 2004 - 9:01 PM)
Um...... dude thats not good. I believe that all cars have those. Check to see if there are any loose hoses or wire connectors that are just hanging around. If not then wtf? lol anyways you might want to look all around for that.
post Feb 14, 2004 - 4:36 PM
belizecelica
Joined Feb 4, '04
From Tampa
thanks guys, i have drilled the hole and replaced the sensor, if i knew a corolla intake would fit i woudl have used that, but at the time I didnt, damn, anyway, the intake still works well, so no problems, just had to put a little more manpower into it.
Lo-Fi Version Time is now: February 24th, 2025 - 2:02 AM
