Apexi avcr boost settings |
Dec 26, 2014 - 2:50 PM |
Enthusiast Joined Jul 21, '13 From Gisborne New Zealand Currently Offline Reputation: 4 (100%) |
hey guys and girls I've got an apex I avcr boost controller what are the recommended boost settings at 0.9 bar ? Thanks
-------------------- Rip Paul walker
'' DUDE I ALMOST HAD YOU '' |
Dec 30, 2014 - 9:52 PM |
What do you mean by boost settings?
Being that it's a ST205, it can handle 1 bar = 14.5psi no problem |
Dec 31, 2014 - 12:25 AM |
What do you mean by boost settings? Being that it's a ST205, it can handle 1 bar = 14.5psi no problem All the settings like Ne point and what time your turbo should kick in etc how do you set that up at 12 psi it's been in the car ever since I bought my st205 I've never played with it the settings thanks lol This post has been edited by hotgt4: Dec 31, 2014 - 12:28 AM -------------------- Rip Paul walker
Jan 4, 2015 - 1:43 AM |
What do you mean by boost settings? Being that it's a ST205, it can handle 1 bar = 14.5psi no problem All the settings like Ne point and what time your turbo should kick in etc how do you set that up at 12 psi it's been in the car ever since I bought my st205 I've never played with it the settings thanks lol Your turbo just starts to spool at a certain rpm range, but also depends on the percentage of throttle input. A boost controller just limits how much or little your turbo will make. You can probably find a PDF online if you search around on Google. |
Jan 17, 2015 - 1:24 PM |
What do you mean by boost settings? Being that it's a ST205, it can handle 1 bar = 14.5psi no problem All the settings like Ne point and what time your turbo should kick in etc how do you set that up at 12 psi it's been in the car ever since I bought my st205 I've never played with it the settings thanks lol Your turbo just starts to spool at a certain rpm range, but also depends on the percentage of throttle input. A boost controller just limits how much or little your turbo will make. You can probably find a PDF online if you search around on Google. Yeah mate thanks Ive done a bit of lurking around on google etc and signed up with gt40c.net seems like a good website, they have a pdf file wich tells you what setting to setting to set your Apexi avcr boost setting cheeers -------------------- Rip Paul walker
Jun 25, 2015 - 2:08 AM |
I played with my apexi avcr in the weekend, And i noticed on 1.1 bar im boosting at 14.5 psi is this normal or should it be more at 1.1 bar ?
At 0.90 its 12 psi, ive got an after market exhaust, down pipe , and pod filter, -------------------- Rip Paul walker
Jun 25, 2015 - 10:10 AM |
Enthusiast Joined Jan 12, '09 From State College, PA Currently Offline Reputation: 1 (100%) |
1 bar is 14.5 psi.
In as much as 1 mile is 1.62 km. Your mods are irrelevant when it comes to a standardized unit of measurement for atmospheric pressure, being converted to a different measurement for pressure. This post has been edited by cardshark525: Jun 25, 2015 - 10:14 AM |
Jun 30, 2015 - 8:27 AM |
Enthusiast Joined Feb 23, '10 From Vancouver, BC Currently Offline Reputation: 0 (0%) |
I played with my apexi avcr in the weekend, And i noticed on 1.1 bar im boosting at 14.5 psi is this normal or should it be more at 1.1 bar ? At 0.90 its 12 psi, ive got an after market exhaust, down pipe , and pod filter, Should be right around 16-17 psi (1.1 bar). You need to adjust the duty slowly up until it reaches This is from alltrac.net Seems to work well for most... QUOTE Apexi AVC-R settings for 0.9 Bar and 1.1 bar
This will give you a basic set up for your APEXi AVC-R boost controller...after this its up to you to play/adjust to suit your car...based on a 3sgte running more or less standard everything. Settings Section Setting [A] 0.9 Bar Boost /Duty Cycle Bst = 0.90kg/cm2 Duty = 52% - You will probably need to adjust this to suit your car NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty Set to 0% in all Setting [B] 1.1 Bar Boost /Duty Cycle Bst = 1.10kg/cm2 Duty = 60% - You will probably need to adjust this to suit your car NE Point NE1 = 3000 NE2 = 3500 NE3 = 4000 NE4 = 4500 NE5 = 5000 NE6 = 5500 NE7 = 6000 NE8 = 6500 F/B Speed 1S = 5 2N = 5 3R = 5 4T = 5 5T = 5 Learn Gear 1S = x 2N = x 3R = x 4T = x 5T = x Start Duty Set to 0% in all Etc settings Car Select Cyl = 4 Spd = 5 Throttle = / (arrow pointing up to the right) Sensor Select Number one (1) Gear Jdge 1st = 120 2nd = 075 3rd = 050 4th = 035 5th = 025 N/S = 255 Graph Scale BS = 2.0kg/cm2 Ne = 8000 RPM Sp = 300km/h Monitor 3 Channel 1 Bst 2 Rev 3 Thr -------------------------------- After this you can start adding one or two % to the start duty in 1st and 2nd grears to get the turbo spooling quicker.....(its more difficult to reach full boost quickly in 1st and 2nd gear even using just a boost controller to control things and bypassing the standard systems) This post has been edited by texasnick: Jun 30, 2015 - 8:28 AM |
Jun 30, 2015 - 12:43 PM |
Enthusiast Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
For the "start duty" add maybe 3% in first and 1.5% in second, it just gives those gears boost a bit of a head start and gets you on full boost slightly quicker.
Lo-Fi Version | Time is now: November 29th, 2024 - 8:48 PM |
