Closed TopicStart new topic
> SOLD: Ksport Kontrol PRO Coilovers
post Jan 18, 2015 - 11:00 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Ksport Control PRO Coilovers for ST204
These are a set of Front and Rear Camber Adjustable Coilovers that I have had for a few years now and they are still going strong. Ksport is one of the only manufacturers that make Rear Camber Adjustable Coilovers for our cars.
These were taken right off the car and have been in great working order and would be perfect for a DD/Track combination.
*The Rear coilovers cant be lowered more until the endlink collar gets loosened and moved up*
other issues are noted below, the price is at the end
FRONT Details
The bottom mounts have scarring on the aluminium from the camber bolts
Top of camber plates (camber plate bolts were just greased with anti-seize)
underside of camber plates
Both front boots are cracked like shown but havent causes any issues
REAR Coilover Details
I replaced the damper in the rear passenger coilover a couple years ago hence the black coating as opposed to the original metal finish.
The paint on this part of the springs is beginning to peel
These are the brackets for the rear endlinks.
The brackets have seized onto the shock body and I wasnt able to adjust it and move it up (this was a couple years ago and havent tried since and I doubt the issue would have resolved itself) This is preventing the rear coilvers from being lowered more.
Rear Passenger Camber Plate
Rear Driverside coilover
This is the ugly ducking out of the group, the coilover is is okay operating condition but could probably benefit from a shock/spring replacement in a couple years. The dampening adjustment knob is stuck in the damper
the camber adjustment screws on BOTH rear coilovers seized up last year and had to be drilled out, you can see that the threads are still in there...I didnt find it necessary to retap the holes and you shouldnt need to use them either. I started to use just a pair of screws for the top hat with a bunch of Anti-Seize and havent had an issues
included with the coilovers are the 3 additional dampening knobs, 4 Ingals Camber Bolts, Coilover Wrenches, Additional Rear Camper Plate Screws, and the Brake Line Brackets to be used with the front coilvers
$SOLD
feel free to ask if you have any additional questions
This post has been edited by Tigawoods: Jan 20, 2015 - 12:38 PM
エキサイティングカーレーシングチーム!
Lo-Fi Version Time is now: December 1st, 2024 - 9:20 PM
