Tire change question / problem? |
Feb 25, 2015 - 2:10 PM |
Enthusiast Joined May 13, '12 From US- NY Currently Offline Reputation: 9 (100%) |
What does this mean?
I have a manual transmission on a 95 GT. I got flat the other day and when I took my tire off (car was running and kept in neutral to keep it heated since it was 20 degrees out) the pegs where I would put my spare tire on were slowly rotating. When I turned the car off it stopped. Is the supposed to happen? If not what is causing this? |
Feb 25, 2015 - 2:50 PM |
Enthusiast Joined Jan 30, '14 From Cortland NY Currently Offline Reputation: 5 (100%) |
What does this mean? I have a manual transmission on a 95 GT. I got flat the other day and when I took my tire off (car was running and kept in neutral to keep it heated since it was 20 degrees out) the pegs where I would put my spare tire on were slowly rotating. When I turned the car off it stopped. Is the supposed to happen? If not what is causing this? Nothings wrong with it, its normal when there is no load on the hubs for the axle to spin slowly. When there is a load on the hubs and car is in neutral it wont do anything. -------------------- 1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool. |
Feb 25, 2015 - 3:23 PM |
What does this mean? I have a manual transmission on a 95 GT. I got flat the other day and when I took my tire off (car was running and kept in neutral to keep it heated since it was 20 degrees out) the pegs where I would put my spare tire on were slowly rotating. When I turned the car off it stopped. Is the supposed to happen? If not what is causing this? Nothings wrong with it, its normal when there is no load on the hubs for the axle to spin slowly. When there is a load on the hubs and car is in neutral it wont do anything. If that's the case, then it's safe to say if I took my other front side wheel off it would spin slowly at a constant rate as well? Also if I removed my rear wheels, would they be still since I have a FWD? |
Feb 25, 2015 - 5:39 PM |
What does this mean? I have a manual transmission on a 95 GT. I got flat the other day and when I took my tire off (car was running and kept in neutral to keep it heated since it was 20 degrees out) the pegs where I would put my spare tire on were slowly rotating. When I turned the car off it stopped. Is the supposed to happen? If not what is causing this? Nothings wrong with it, its normal when there is no load on the hubs for the axle to spin slowly. When there is a load on the hubs and car is in neutral it wont do anything. If that's the case, then it's safe to say if I took my other front side wheel off it would spin slowly at a constant rate as well? Also if I removed my rear wheels, would they be still since I have a FWD? That would be the case with all of it, if you just jack the front up the wheels will start to spin slowly in neutral unless you put some force against it. The rear wheels are just hubs with bearings, no drive mechanisms, so they wouldn't move unless you move them by hand. -------------------- 1997 ST:Limitedly Green
Feb 25, 2015 - 6:34 PM |
Thanks for clearing that up for me. I guess ive never had my car running before when changing a tire on the front end.
Lo-Fi Version | Time is now: December 4th, 2024 - 10:36 AM |
