> 96 GT randomly won't start
post Mar 24, 2015 - 6:32 PM
grntrefrog
Joined Mar 2, '15
From United States
New owner, wondering if anyone has had or heard of anyone who has had this problem. I bought it a month and a half ago, a used motor with less miles was put in at the time when I bought it. They put in a new starter, battery and alternator. About a week ago it didn't start, I took it to the mechanic twice, they changed the battery twice. Still having problems with it starting, anyone have a clue?? Think it could possibly be electrical problem.
UPDATE:
Problem seemed to go away on it's own, had no problem starting for about a month and a half; went out again one day, and it had the same problem. Seems to have gone away again. When this happens the relay clicks once and she has power. Seems I'll be playing Russian roulette every time I go out to start her.
This post has been edited by grntrefrog: Jun 4, 2015 - 11:21 AM
post Mar 24, 2015 - 8:25 PM
Box
Joined Feb 23, '12
From Warrior, AL
When it doesn't start does the car still have power? If so does it try to turn over or does only the relay click if that? It could be during the engine swap some grounds were forgotten or not tightened all the way.
2001 Miata LS 5-speed
post Apr 13, 2015 - 12:06 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Box @ Mar 24, 2015 - 9:25 PM) *
Change the coolant tem sensor it gets corroded on the inside and you cannot see it. It is the right one from where the top hose goes to the engine. Mine was cracked after replace($15( no probs for years starting).
good luck
FYI the left one is for your guage inside
post Jun 4, 2015 - 11:18 AM
grntrefrog
Joined Mar 2, '15
From United States
Only the relay clicks once, doesn't do anything else, and it still has power to everything. Been fine for the last couple months then did it again about a week ago but went back to normal
post Jun 11, 2015 - 4:01 PM
gazad91
Joined Apr 22, '14
From ireland
Yea Definitely sounds like an Earth(Ground) problem . Had the same with mine. would start perfectly for a month or more then randomly not start.
naturally i thought it was the battery so i bought a new one and bang it started again..until a week later and same thing happened..ran a multi meter on the battery and
it checked out fine .then i thought it was maybe a starter problem...while i was looking at the starter i found an earth(ground) cable just hanging down where it should
have been held in with one of the starter bolts..that cured it all
Lo-Fi Version Time is now: November 29th, 2024 - 8:48 AM
