1mz celica front spring rate |
Mar 25, 2015 - 5:13 AM |
Enthusiast Joined May 27, '08 From Oz Currently Offline Reputation: 0 (0%) |
Hey all you guys with a 1mz / 3mz swapped celica - what spring rate are you running on your coil springs? I'm not sure if my 4 cyl sports springs have sagged with age or the extra weight of the v6?
Cheers -------------------- 1MZ-FE 3.0L QUAD CAM V6
E153 5SPD MANUAL GT4 FRONT END |
Mar 25, 2015 - 8:29 AM |
Enthusiast Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
snapshotgt I think the members name is who did a V6 had a little bit of info on his strut and spring setup for his swap. Are you looking for coilover spring rate or spring rates for spring/strut setup?
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Mar 25, 2015 - 1:21 PM |
im using OEM struts and springs. i havent noticed any sag. Im willing to bet that a 1MZ/3MZ with a 5 speed weighs about the same as a 5S with an auto trans. im sure its negligible
This post has been edited by Smaay: Mar 25, 2015 - 1:22 PM -------------------- 2001 Celica GT-S Turbo
Mar 25, 2015 - 5:13 PM |
^Yup. The 1MZ is all aluminum whereas the 5S is an iron block with aluminum head, so the weight difference is closer than you'd think.
Mar 26, 2015 - 2:20 AM |
Enthusiast Joined Mar 8, '12 From Hanford/Fresno, Ca Currently Offline Reputation: 20 (100%) |
Yea. You shouldn't have trouble. Iirc the 1mzfe is about the same weight as the 3sgte.
Mar 28, 2015 - 2:02 AM |
Thanks guys - I guess my springs have just sagged with age then. They seem soft as and if I slam the brakes on the nose dives like crazy. Added to which I can't go over a bump in the road faster than 40km an hour or the front end bottoms out. I'll see if I can look up snapshotgt's post re suspension setup.
Mar 28, 2015 - 6:16 PM |
If you're using cheapo springs they'll always sag and give out eventually. Might look into coil-overs.
Mar 28, 2015 - 10:46 PM |
Thanks guys - I guess my springs have just sagged with age then. They seem soft as and if I slam the brakes on the nose dives like crazy. Added to which I can't go over a bump in the road faster than 40km an hour or the front end bottoms out. I'll see if I can look up snapshotgt's post re suspension setup. I think your struts might be blown. Sounds more like that than the springs sagging. If you push down on the front of your car and it keeps bouncing, then they're blown. This post has been edited by mkernz22: Mar 28, 2015 - 10:46 PM |
Lo-Fi Version | Time is now: November 29th, 2024 - 11:05 AM |
