Enthusiast ![]() Joined Nov 29, '12 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
Hey guys
I went to check my oil the other day, and when i pulled out the dipstick i could smell a faint smell of petrol.... Obviously that doesn't sound great... ![]() It seems to be running fine. No sign of smoke etc. My fuel consumption has increased but thats more likely the fact i've moved to town and am now doing a lot of stop go driving... Im going to pull out the sparkys tonight and see if they're screwed - Is there anything else i should check??? Mines a 3SFE Thanks! Liam -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) ![]() |
Could be injectors are leaking, or the fuel pressure is too high due to a faulty fuel pressure regulator. The other possibilities being plugs are fouled/worn and not igniting the fuel mixture properly. Worst case rings are letting blowby occur, though usually you'd have oil burning happening as well.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) ![]() |
its normal. theres no such thing as a perfectly sealing piston, even when brand new
It shouldn't reek of fuel though, a slight odour is normal.
Just saw where it said faint. Yeah, if there's 3,000+ miles on the oil and it's a faint smell you're fine. Though a tuneup wouldn't hurt if it hasn't been done in awhile. -------------------- 2001 Miata LS 5-speed
It shouldn't reek of fuel though, a slight odour is normal. Just saw where it said faint. Yeah, if there's 3,000+ miles on the oil and it's a faint smell you're fine. Though a tuneup wouldn't hurt if it hasn't been done in awhile. Yeah I'm sitting at about 9K kms ( about to do one shortly ![]() I haven't exactly had alot of money lately so I've been really slack in terms of maintenance ![]() ![]() Lets just say my accelerations alot nicer ![]() -------------------- ![]() |
Thought about the other day then forgot to reply, a clogged PCV valve can also cause it as then the car won't burn off the oil contaminants.
Lo-Fi Version | Time is now: February 18th, 2025 - 3:41 AM |
